It worked as a charm... thank you very much! How do you do it??
first post should be here Introduce Yourself
say hello and join the community
in the meantime try bkuhvi97
Hi! My uncle gave me his old Dell notebook, but I can't nor boot nor access bios. Could you provide me the 2 passwords? It's a Latitude D520, service tag JRRBL2J, Express Service Code 430-373-412-91. Gonna put a post on the introduction section right away
it worked like a charm. many thanks
Yes, I have a D520 that I need a bios password for. PLEASE ASSIST!
#495X6B1-595B - (Not sure if you need the last part, but fingured I would add it.)
Thanks in advance!
Hi smoggy im having problems with a Dell Latitude D520.
The code is #69D243J-595B
The code is as it is above all in upper case if that helps.
Thanks for any help
Hi brenandlaura
in the meantime try 7v4saazq
Hi thanks that worked a treat but i now have a second problem.... it wants the code for the hard drive now.... its #***5LY7787R-595B
Thanks again
thanks everything worked a treat. Is there a programme to generate the codes or is it something you own yourself. Only asking as if i can help others with the codes then i will. Thanks again.
Smoggy!
You are the BEST!!!
Thank you!!!
Hi i have a dell D520 with locked bios!!
someone can help me plz?
service tag : G0BBM2J-595B
thanks a lot
in the meantime if 2nd is zero password rwyctp4q
if upper case O then 49fc7lhv 6th is l for leg
