Page 1 of 46 12345611 ... LastLast
Results 1 to 15 of 690
    Default DELL D520 administration password
    Hi I have an DELL D520 and I need the master passwd for BIOS ,or how can I disable the administration password at startup. is something like #HQKDP2j-595B .I read something about to replace the keyboard controller but I read that is necessary to read the BIOS flash (sst25vf080b) and to disable the BIOS password or to change it with another one that I know .I put the file in the archive and upload it here .
    Thank you very much.
    Junior Member wgnrblay's Avatar
    Remove from mains, take out battery, open up the back and see if the battery on the mainboard is accessible, if it is remove it for 1/2 hour and then put back in. With luck the password will have gone. You will have to set date/time again.
    dasteph's Avatar
    Nov 2008
    north east
    have you tried dell support and asked them to supply you with a master password.
    Default Dell D520
    Is not working by reomving the BIOS battery or any other baterry ....And I'm not try to contact dell suport because my friend had buying that notebook from internet and that was ....a BIG mistake ..... MAYBE that NOTEBOOK is bricked .
    V.I.P. Member cgscott's Avatar
    Jul 2008
    cmd
    Quote Originally Posted by craul4 View Post
    Can you boot into windows?
    If so boot into safe mode by pressing f8. Once in safe mode
    ctrl+alt+delete. task manager
    File run.. type control userpasswords2
    Remove all admin and change passwords.
    Reboot into windows and all is done.
    Patience is a virtue.
    V.I.P. Member Curious123's Avatar
    Apr 2008
    To get round the BIOS password you would have to call Dell and they will ask you for a number that appears on the BIOS screen . Once they have that number they will give you password which will unlock the BIOS password.
    Having problems with dell bios password??
    post here your service tag
    cheers
    Oct 2008
    I know its a little late but if you still have this problem here is the password:
    vm6kd720
    rex89's Avatar
    Not Near Tricore MCU
    Hi, craul4 first when you ask for the password for the administrator password repeat until it will show you an error post the error and with that I could password by default
    Apr 2011
    Default SERVICE TAG 7B8HB3J
    Quote Originally Posted by egyclick View Post
    cheers
    Sir here is my service tag number..It is 7B8HB3J..
    Hoping for your reply...Thanks very much in advance...
    Apr 2011
    cheers
    smoggy's Avatar
    Apr 2009
    UK North East
    Quote Originally Posted by ACER2270 View Post
    if your tag ends 595B then password ho0tzl9b
    2nd is o for orange 3rd is a zero
  13. #13
    Apr 2011
    Default Dell D520 bios password
    hello, i got a dell d520 which is bios password protected, i got this from ebay and the seller sold it to me as is so no support there the service tag is 9K14G2J-595B
    thanks in advance to whoever can help me
  14. #14
    smoggy's Avatar
    Apr 2009
    UK North East
    Quote Originally Posted by DarkSoulV View Post
    before asking for help your first post in the forum should be here Introduce Yourself
    in the meantime try 81uyro69 (sixth is o for orange)
  15. #15
    Apr 2011
    Default Thanks
    sorry about that, thanks it work right away
