Results 1 to 15 of 23
    Senior Member smotorsport's Avatar
    Feb 2018
    Default Audi A4 B7 3.0tdi v6 edc16cp34 hardcut limiter?
    Hi, can anyone make hardcut in this ecu? Car is auto and in park/neutral won't rev over 4k rpm. And I want hardcut at let's say 4200 only in N/P. Here ori.
    Feb 2018
    Someone???
    Feb 2018
    At least someone knows how its named in damos that limiter?
    Feb 2018
    Still strugling with that limiter...
    rfernandes's Avatar
    Jun 2018
    portugal
    hi there!!look on 1EDB0D 8bit will apeear like this 14 B4...press delete and select b4;then press K and change to 16 bit hilo,will apeear 5300 rpm..
    i think it ill be work only in N...have a try my friend
    Jul 2017
    Quote Originally Posted by rfernandes View Post
    it will not work because he wants popcorn at 4,200 rpm, and he wrote that "Car is auto and in park/neutral won't rev over 4k rpm."
    rfernandes's Avatar
    Jun 2018
    portugal
    hummm..ok
    so you can try 1EDAFA same procedure..its 3950rpm..it can be this one
  8. The Following User Says Thank You to rfernandes For This Useful Post:
    smotorsport (17th September, 2018)
    Feb 2018
    Thanks for the replies, will test tomorrow and report
  10. #9
    Jul 2017
    hummm..ok
    I'm sure this is not it. Description of this map in German: Einspritzmenge pro Einspritzung (mg/Einspritzung)
    Unfortunately I will not be able to help you. Maybe someone more experienced will help you.
  11. #10
    Feb 2018
    Yep That's NOT the limiter I saw it in damos too, but still decided to test and nothing changed... I'm getting desperate already...
  12. #11
    Oct 2014
    Latvia
    try this one.
  13. The Following User Says Thank You to kaadzis For This Useful Post:
  14. #12
    rfernandes's Avatar
    Jun 2018
    portugal
    sorry mate
  15. #13
    Feb 2018
    sorry mate
    No problem. I really appreciate your effort. Thanks
  16. #14
    Feb 2018
    Thumbs up
    Quote Originally Posted by kaadzis View Post
    try this one.
    Thanks. I couldn't try on that a4 but I think it will work only if that limiter is changed in codeblock 2 for auto. But I tried it in my own car (A6 4F 2.7tdi), there the map is not 25x1 but 10x5 that looks like launch control map like in old edc15p ecu's AND IT WORKED. To be honest i've noticed that map early when I made stage 1 but when I saw 10000 values I tought that couldn't be the limiter. So i'll test tommorow on the A4 and report. Thank you very much kaadzis.
  17. #15
    rfernandes's Avatar
    Jun 2018
    portugal
    have you try on A4?
