basim88 (2nd February, 2020), PatricioPanama (19th December, 2018), skens (10th October, 2022), srico2401 (28th March, 2019)
Hi possible with emu
PatricioPanama (1st January, 2019)
immo off possible,check pm
alderik789 (11th February, 2019), antonypaul (9th August, 2023), basim88 (12th February, 2020), CarDiagAMG (20th May, 2020), Cjnek (8th September, 2018), Hyperion6173 (14th January, 2021), InchisNonStop (4th May, 2019), kamilt (28th October, 2021), nagybela (9th November, 2019), PatricioPanama (1st January, 2019), skens (21st May, 2021), srico2401 (28th March, 2019), Stelaras26 (14th September, 2022), Toutancamon (16th October, 2020)
basim88 (12th February, 2020), makilaki (20th February, 2020), Stelaras26 (14th September, 2022)
Hi, there is a problem with Hyundai I30 petrol 2010 edc BOSCH 0281017206, a friend arrived and says that it is started up 1 time out of 20. The problem is with the immobilizer and it is necessary to disable it. My friend read full without picking up the block. I ask you for help. Thank you.
sorry friend, this is a diesel, I repaired the unit petrol ecu in front of this machine, and therefore I mixed it up. What is the password for the archive? to record you need to disassemble the ecu block? the immobilizer error is recorded in the engine block, the immobilizer block alone is not diagnosed.
I have solution only for petrol Kefico ecu.
After you write modified dump to eeprom you need to remove immobox before you try to start.
Pass in PM.
Sorry, but this method is not suitable for this unit.
I can not defeat this unit, immo off edc17c08, if anyone can help, I ask for your help. Thank you.
magic flex
por favor pase?
