Results 1 to 3 of 3
    Dec 2013
    Default Auid A6 c6 engine ecu software update
    I'm looking for engine ecu software (BDM read) for Audi A6 c6 3.0TDI BMK.
    Ecu is 4F0 910 401 S 000AG 0040
    I need software version 0060.
    Problem is I cannot perform DPF replacemnet adaptation using diagnostic tool (DPF was replaced).
    As far as I know solution is software update.
    VAG provided Technical Problem Information (TPI2012786) for this issue.
    I'm going to write new version via BDM.
    Dec 2013
    Sorted out.
    I found version 0050 for this ecu numbers.
    DPF replacement adaptation works on this version. (Calculated Carbon mass
    is 0 now).
    morfej's Avatar
    the requested 060 firmware.
  4. The Following 3 Users Say Thank You to morfej For This Useful Post:
    alclot (26th March, 2019), Electro88 (15th April, 2025), mbi (10th September, 2018)
