Steering problem's Clio III 2006
Results 1 to 5 of 5
    pinheiro's Avatar
    Dec 2009
    Portugal
    Default Steering problem's Clio III 2006
    Hi friends
    I have problem with a Clio III 2006, sometimes the steering doesn't work.
    By clip diagnostic it appears the following dtcs:
    DF054 - sensor de binário
    DF038 - Sendor de ângulo
    If I replace onle the motor part can I solve the problem? Or do I need to replace the all set (ecu+motor part)?
    Best regards
    Pinherio
    Jul 2013
    yorkshire
    If its only "sometime" i would go to battery first. Test it under load.
    Sep 2015
    if this happens only in the beginning it can be either the battery or the capacitors. otherwise you may have a problem with the eps group motor hall sensors. otherwise there is the possibility that it has resistsze and unshackled SMD capacitors.
    UK
    Replace with another and program
    Nov 2018
    New Delhi
    Hi! I had a similar situation with my Renault Lodgy . Spent a lot of time thinking the problem could be solved easier. But ultimately had to replace with another one and program, as written above.
