Results 1 to 11 of 11
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Default Audi 3.0Tdi EDC16CP34 DTC P3348
    hi...
    I have a Audi A4 3.0 tdi here with an edc16cp34, SW: 1037376009, SW Upg.: 8E0910401F 0050...
    itīs pssible to delete dtc p3348 and p0235?
    Jul 2013
    Latvia
    Hi! Try this.
  3. The Following 2 Users Say Thank You to flashtech For This Useful Post:
    figani (8th September, 2018), TPS (13th September, 2018)
    Mar 2013
    Random
    but how you drive it without turbo?
    figani's Avatar
    Feb 2018
    car works normal, after 3 o4 days it goes in limp mode... start again everything well...
    you have a better solution?
    Jan 2018
    shaftesbury,Dorset,UK
    Quote Originally Posted by figani View Post
    find the problem always better than delete ? sticky vanes maybe?
    Jan 2018
    change turbo actuator!!
    figani's Avatar
    Feb 2018
    customer changed both... new...
    Jan 2018
    ah bugger its one of those is it.... wiring or ecu then probably, also check all fuses for actuator they can go bad apparently, bloody electric actuator vac system was much better
  10. #9
    figani's Avatar
    Feb 2018
    car have 448567 kilometers... car drove normal... still want not longer limp mode... thatīs all...
  11. #10
    Jan 2018
    the chances are whatever is going wrong even for a few seconds will cause the car to behave badly for a few seconds or loose power. If you delete limp mode still be prepared for the odd chuff of smoke and power loss... I dont see this being a great solution but i have been proven wrong many times before buddy
  12. #11
    Mar 2013
    Random
    if but if it is new actuator then u can have problem with small actuator for vacuum on egr cooler.Sometimes internal resistance of that valve may be prob for ecu and manifest in that way.
