Results 1 to 12 of 12
    Top Poster mack0r's Avatar
    Mar 2017
    Default TVA off solution
    Hello
    Can you tell me how do TVA off in EDC16 edc15?
    I need only DTC off or more?
    Inquizit0r's Avatar
    Aug 2013
    Ukraine
    You need more.
  3. The Following User Says Thank You to Inquizit0r For This Useful Post:
    mack0r (11th September, 2018)
    mancioks's Avatar
    Feb 2017
    Germany
    And it's not same for all ecu's.
  5. The Following User Says Thank You to mancioks For This Useful Post:
  6. #4
    Mar 2017
    Hmm can you explain what maps or switch I need touch? And how?
    Mar 2017
    Thanks for help
  8. #6
    Jul 2013
    Latvia
    Quote Originally Posted by mack0r View Post
    Seems like You don't understand. There is no global solution for all ecus/cars. For different ecus there is different solutions, even type of engine makes difference... For example : Solution which works on Audi EDC16, will not work on BMW EDC16.
  9. The Following 2 Users Say Thank You to flashtech For This Useful Post:
    mack0r (12th September, 2018), mancioks (12th September, 2018)
  10. #7
    Mar 2017
    Ok. In this case how I do TVA off?
    Car is Audi a6c6 2.0 TDI 136hp
  11. #8
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    delete dtc and will work
    Chiptunning / EGR / DPF / FAP / DTC / FLAPS / Adblue / ETC.... CUSTOM SERVICE / FILE SERVICE / 24/7 Support
  12. The Following User Says Thank You to Ignasvw For This Useful Post:
  13. #9
    Mar 2017
    earlier others wrote delete dtc is not enough
  14. #10
    mancioks's Avatar
    Feb 2017
    Germany
    Because You not write what car or ecu you want remove.
    If you don't have limp mode just delete DTc, if have limp there is needed to do more.
  15. The Following 2 Users Say Thank You to mancioks For This Useful Post:
    flashtech (12th September, 2018), mack0r (12th September, 2018)
  16. #11
    Mar 2017
    Ok. In this car I search P3101, P3102, P3103 and I can not find.
    I think P-code is 4x415 and start 1CB0D0
  17. #12
    johak's Avatar
    here you go
  18. The Following User Says Thank You to johak For This Useful Post:
