Egr off by hysteresis need connector plugged.
what dtc you get in ECU with plug disconnected ?
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into your
(")_(") signature to help him gain world domination.
Have not faults in ECU, but there is fault in ABS/ESP U1208.
Actualy this version works with egr disconnected and DTC U1208 in ABS.
Any solution to remove U1208? I tried to disable all dtc's in fault class table and again have U1208 in ABS. I think there is other location outher fault class table to disable this DTC.
this is good solution working 100% ... have not removed any DTC ... just remove whatever error you have with plug disconnected
you won't get U1208
pass: PM
(\__/)
proel (11th September, 2018)
Tommorow I'll test file and report.
Thanks!
