Hello,
I'm not able to download on this section. Can you please help me?
Thanks!!
Hello,
Can you please help me with the activation of Delphi 2016
Thanks in advance.
Best regards,
Alex
[QUOTE=guediix;3836893]Hello,
It worked perfectly thanks a lot for you quick action.
I have a second laptop can I use the same file or I have to gnerate a new one and activate it too?
Can you please activated my file for second laptop (Delphi 2016)?
Don't work.
It says Operation failed.Please check that installed version is valid for your type of VCI.
I delete Delphi2016 and install Autocom2016.0 Car Setup.
QBGIGRITVACE
Cars CDP+
2.13.3
New file.
Should the internet be on or off ?
delphi 2016 Karine
don't forget to press the thank you and reputation button !
Guediix delphi 2016
Lasa un telefon ,ceva cum crezi ca te putem ajuta ? trebuie incercat cu team viewer !
0742818384. ms .
Can you tell us if the OBD2 socket was connected to the car or powered from the 12Vdc external source? I tend to think not.
That's what I think is the problem for you. So, go with your laptop to the car, plug in the OBD2 jack, eventually reinstall the drivers if needed and then do the test.
Or, give us more details.
