Page 2 of 9 FirstFirst 1234567 ... LastLast
Results 16 to 30 of 121
  1. #16
    May 2011
    I have been using this device CH341 for readinng and programming mainly BIOS for PC. I m trying now to read a 5P08C3 eeprom from my ECU to get the file and write it into a donor ECU eeprom. It seems the reading is ok (however I get sometimes different readings). My understanding is that it is possiblr to mod the CH341. M;y intent is to put a switch so that I can give 3,3 or 5 volts. I guess the 5 volt MUST be supplied to the Vcc pin (pin 8) of the chip. Is this correct?
  2. #17
    Jan 2020
    Hello, i know this post is old. I modified my programmer like the first post. But everytime i try to read the EEPROM the reading is only "FF FF ...""
  3. #18
    Nov 2019
    Ukraine
    I was able to read 95320 chips from radio and immo w/o modifying programmer. Used AsProgrammer from here https://github.com/nofeletru/UsbAsp-flash/releases (select correct chip type via IC - Search). I was checking correct pinout with multimeter to see that Ground on programmer's USB and Ground on ECU are the same. I used clip to read chip w/o soldering it out.
  4. The Following 5 Users Say Thank You to hadesinua For This Useful Post:
    antonypaul (5th August, 2023), arthueascii (4th September, 2021), Col19 (19th August, 2020), pantvas (5th August, 2022), zappaf (28th March, 2020)
  5. #19
    Mar 2008
    @hadesinua - thanks. With AsProgrammer I read 95640W - Blaupunkt -RCD 300 with soic8 (I modify cheap CH341A eeprom).
  6. #20
    Mar 2016
    Default How to use cheap CH341A programmer for read/write 95xxx Eeproms
    Just wanted to say I really appreciate who made this guide I too was able to read some eeproms with this method. For those doing the mod I know this is self explanatory for some but for me wasn’t strait forward, this is how you do the capacitor mod. Also I added a file you can replace in AsProgrammer to get more types of chipsets in the search chiplist.zip
  7. The Following 5 Users Say Thank You to ferrarikid For This Useful Post:
    Col19 (4th June, 2021), fuzz1 (9th December, 2020), pantvas (5th August, 2022), parrafin23 (14th August, 2021), zappaf (28th March, 2020)
  8. #21
    Aug 2016
    thanks its work fine...... this a look ...thankyou
  9. The Following User Says Thank You to omar25py For This Useful Post:
  10. #22
    Apr 2020
    UK
    Many thanks for the howto, worked a treat to read a st95080. Thanks again.
  11. #23
    Jun 2020
    I am trying to get the pin code out of the IPC on a Opel Corsa D. Where the data is on the eeprom M35080
    I have this CH341A board i have used to get the eeprom data out of the ECU and now modded to 5V to read eeprom on IPC.
    I can confirm it also work with eeprom M35080VP - With a homemade adapter cable
  12. #24
    May 2008
    Sorry guys a bit late on this post as I just saw it, to make the CH341 programmer read and write 95xxx eeproms you don't need to modify or add anything as everything is provided onboard, just move the jumper and it should read/write fine if it doesn't for some reasons then add two jumpers (one=original jumper and second=another jumper as shown in picture). Check the attached photo and move the jumper or add another to read/write the 95xxx eeproms.
  13. The Following 7 Users Say Thank You to da14u For This Useful Post:
    Adiadi (21st August, 2020), Col19 (4th June, 2021), pantvas (5th August, 2022), r3aperx (16th July, 2020), rottor (4th September, 2020), seal777 (2nd September, 2022), Smitten8r (7th October, 2023)
  14. #25
    br556hre's Avatar
    Just adding M95160 and M95080 PDF specs.
    If you have "W", "R" or "S" on end of chip you don't need 5.5V.
    Only M95xxxx without any additional letters requires 4,5 - 5.5 V.
  15. The Following 4 Users Say Thank You to br556hre For This Useful Post:
    Col19 (19th August, 2020), marwan26 (10th June, 2023), pantvas (5th August, 2022), rysiek2 (4th November, 2023)
  16. #26
    Aug 2020
    Spain
    24C32 Fis can be read using this type of adapter? Any guide as how can be done?
  17. #27
    br556hre's Avatar
    yes adrianux, 24c32 can be read, no problem. Just take care to connect pin 1 correctly!
  18. #28
    Here’s a good video explaining it all guys.
    https://youtu.be/hPKckby54uA
  19. The Following 4 Users Say Thank You to AudiS4 For This Useful Post:
    antonypaul (6th August, 2023), Richie98 (14th July, 2021), rysiek2 (4th November, 2023), stutar (14th November, 2021)
  20. #29
    I cant get this programmer to work keep getting connection error -1. Any ideas?? Unmodified, trying to read a st95128RT
  21. #30
    May 2016
    Because the pin 1 is wrong. If you change the connector, you will get device connected.
