Page 5 of 9 FirstFirst 123456789 LastLast
Results 61 to 75 of 121
  1. #61
    fuzz1's Avatar
    Jul 2019
    Yes why not. Share the pic thanks
  2. #62
    So I purchased another ch341a reader that matched this thread. I tried reading a chip with 2 jumper and got error that the usb was shorted or didnt have enough power to supply the circuit. Anyone else run into this??
  3. #63
    fuzz1's Avatar
    Jul 2019
    Quote Originally Posted by AudiS4 View Post
    The truth is that i tried it too an gave up using the ch341 a
    I tried with the two jumpers and failed.
    Some say it works with only one jumper.
  4. #64
    Feb 2020
    Rotterdam area
    You have to modify your CH341a to 5V (for 95xxx)....or to 3.3V (for 25xx).
    I have sucessfully read/wrote Atmel 25320AN from PuntoEvo airbag modulewith 3v3 modified CH341a.
    Good explanation (and startpoint to figure both 5V and 3v3 mods is here) : https://www.onetransistor.eu/2017/08...schematic.html
    Further, for programming on a Windows 10 laptop, you need NeoProgrammer....AsProgrammer can read but not write reliably (at least not on my Dell lattitude with Win10)
  5. The Following User Says Thank You to neerco For This Useful Post:
    fuzz1 (4th June, 2021)
  6. #65
    fuzz1's Avatar
    Jul 2019
    Thank you for your contribution however it's the first time I'm hearing this thing about asprogrammer being unreliable.
  7. #66
    Jan 2020
    Ukraine
    I use NeoProgrammer, suported 95xx and SP08 ICs without any modifications with power of CH341A
    Try and tell us
    What do you think about it?
  8. The Following 7 Users Say Thank You to alex56384 For This Useful Post:
    cone96 (17th August, 2021), jokas (11th July, 2021), mehmet3531 (25th July, 2022), ombre57 (15th November, 2023), pantvas (5th August, 2022), rysiek2 (4th November, 2023)
  9. #67
    Feb 2020
    Rotterdam area
    It may be due to Win 10. I noticed when trying to write with AsProgrammer....it completes writing "too quickly" - basically instantly.
    Only 1st 32 bytes are written properly.
    Neoprogrammer writes slower (you can see progress bar progressing...writing AT25320 takes few seconds). And error free, entire 4kByte
    I got it from here: https://khandishnetwork.com/2020/07/...ftware-update/
    As for modifying CH341A. It may not be necessary...but is correct thing to do.
    CH341A from aliexpr as is, is not fine.....it supplies target device with 3v3 supply, while driving data on 4.7V. All is explained in the link in my post #64
  10. The Following 2 Users Say Thank You to neerco For This Useful Post:
    fuzz1 (9th June, 2021), rysiek2 (4th November, 2023)
  11. #68
    br556hre's Avatar
    Quote Originally Posted by fuzz1 View Post
    Can you explain what you mean by take care of pin 1?
    pin 1 marks starting point to numerate all pins, if you get it wrong you might not be successful to read or even make damage to chip.
  12. The Following User Says Thank You to br556hre For This Useful Post:
    fuzz1 (13th July, 2021)
  13. #69
    Mar 2017
    Hi, can aynone show me what to cut here, maybe draw on the picture?
    I'm not sure how to cut 3,3V line. Thank you
  14. #70
    gabriel pablo's Avatar
    Mar 2019
    argentina
    hello, I have read eprom 95640 with ch341a without cutting or bridging anything, only with neo-programer
  15. #71
    Mar 2017
    Actually I did that too with 95320wq. As someone stated, those work on 3,3v also.
    I need to do one more, i hope it is also 3,3v.
    Sent from my SM-T819 using Tapatalk
  16. #72
    Smart66's Avatar
    Dec 2020
    It'll be better set supply to 5V. What device's E2P do you want to modify?
  17. #73
    Sep 2021
    FYI I successfully used a CH341A programmer without modification other than adding condensator in the input voltage to successfully read/write a 95128RT (https://www.st.com/resource/en/datasheet/m95128-r.pdf) eeprom. No 5.5v modification is necessary, not adding jumper to use 5v. The 3.3v is in the range of voltage of this chip.
    Probably works also without adding condensator.
    Pinout of the chip is exactly the same as the 25xxx models.
    To program I used AsProgrammer (https://github.com/nofeletru/UsbAsp-flash/releases/) latest version in my case (2.0.2) that manage st95xxx chips.
    A note, trying to connect the chip without desoldering do not allow the CH341A to be recognised as usb device (in win10). I didn't test on linux with flashrom command line application.
    BTW thanks for this thread that gave me great help to win the fear to desolder and reprogram the eeprom.
  18. The Following User Says Thank You to ginettoginetto For This Useful Post:
    blackground (18th November, 2021)
  19. #74
    Jul 2021
    Super danke
  20. #75
    Apr 2022
    I'm trying to read a RL56 chip (i'm reading its the same as a 93c56) with a ch341a and as soon as I put the clip on, the usb dies
