Results 1 to 7 of 7
    Feb 2017
    Default Need BMW 118d Edc17 immo clone
    Hi man,
    i have both Bootmode Files from old_damaged_ecu and new_used_ecu
    please can you do immo cloning
    Its an BMW 118d EDC17cp02
    thank you very much
    carmageddon's Avatar
    Italy
    i had similar problem (ecu under water), i buyed one ecu , i wrote flash and e2p via boot mode (without immo off) and place ecu in the car...the car started and worked right.
    have you tested this step?
    Feb 2017
    Quote Originally Posted by carmageddon View Post
    i not tested this stuff,
    you mean , i only need write Bootmode files in new buyed ecu and this works ??? really ? like EDC16 BDM files .
    Italy
    not all edc16/17 work this operation....in my case have worked, try it, have no cost
    johak's Avatar
    write this in new ecu and try
  6. The Following User Says Thank You to johak For This Useful Post:
    stanislav georgiev (17th September, 2018)
    robert1232's Avatar
    Dec 2010
    Ireland ;)
    Default immo bmw
    try this and report
    dont forget magic button
    pw
  8. The Following User Says Thank You to robert1232 For This Useful Post:
    jpg123 (8th January, 2019)
  9. #7
    Jan 2018
    hi ..i have the same problem..can you help me with this edc17cp02 dump for immo off
    regards
