Results 1 to 8 of 8
    MACKIE's Avatar
    Jan 2011
    Helion Prime
    Default P308 replace BSi problem
    have issue with replaced BSi on P308 y2010 1.6HDI.
    Replaced BSi-virginise it, adaptation was succesfull (vin, keys, ecu-s...).
    But now have error "Engine Faulty" and check engine blinking, everything other is working ok...
    No errors in BSI, only one double error in ecu U1218-Intersystems CAN.
    BSI Data:
    Johnson Controls
    9666647080
    SW index:5.02
    sw signature: 27.8B
    ECu data:
    Siemens SID 807
    9678917680
    sw index:255.255
    sw signature: 00.00
    Anybody have same problem?
    Solution idea?
    Regards
    Mackie
    " I don't need help but difficulties. The harder the better. I work the best when in trouble."
    Dec 2009
    You use DiagBox but not PP2000 ? Look in full details of U1218 in ECU, if it point to gearbox ECU or ESP/ABS or BSI ?
    What type of the gearbox ?
    MACKIE's Avatar
    Jan 2011
    Helion Prime
    Solved,
    it's not diagnostic problem, and I used Diagbox...
    It's not about gearbox or ESP/ABS
    it's all about incompatibility od fw in BSi and ECU.
    Regards
    Mackie
    Quote Originally Posted by Zmann View Post
  4. The Following User Says Thank You to MACKIE For This Useful Post:
    filxomor (15th January, 2023)
    Dec 2009
    I'm aware of this communication fault code and this can be found in Peugeot TSB (Technical Service Bulletin), that why my question was if the fault point back to a specific module in the CAN network.
    Regards,
    Quote Originally Posted by MACKIE View Post
    Solved,
    Regards
    Mackie
  6. The Following User Says Thank You to Zmann For This Useful Post:
    fuzz1 (25th January, 2023)
  7. #5
    t77's Avatar
    Poland Lodz
    Check cruize control telecoding
  8. #6
    Aug 2011
    Spalding
    Quote Originally Posted by t77 View Post
    I think he's sorted it.
  9. #7
    Jul 2014
    Solved,
    Regards
    Mackie
    Hi mate
    I have the same probleme
    How you solved your probleme?
  10. #8
    ricked's Avatar
    Apr 2016
    Europe
    Quote Originally Posted by filxomor View Post
    Hi mate
    he dit say what the solution was:
    "it's all about incompatibility of fw in BSi and ECU"
