Page 1 of 3 123 LastLast
Results 1 to 15 of 45
Hybrid View
    z786's Avatar
    10 Steps Ahead of You
    Exclamation Audi Q7 2014 all keys lost
    Hi, i have the CS PIN and MAC from edc17 ecu
    i input those 6 bytes and pin in ezs via AVDI, it lets me read VIN ID and also Key adaptation (login OK) but i cannot prepare dealer key, while reading ecu it gives up, any ideas how to go from here
    "I always tell the truth. Even when I lie"
    "We Taking Over, One City At A Time"
    drugowaz's Avatar
    Mar 2015
    Lithuania
    6bytes not enough. Its bcm2 car. Itcould be as a6 c7 akl need bmc dump and elv dump
  3. The Following User Says Thank You to drugowaz For This Useful Post:
    z786 (21st September, 2018)
    yugo45's Avatar
    Quote Originally Posted by drugowaz View Post
    Q7 till 2016 is same as old 2007 . 2016 and up is BCM2 cars.
  5. The Following 5 Users Say Thank You to yugo45 For This Useful Post:
    doctore (22nd September, 2018), dritan (23rd September, 2018), igorr (22nd September, 2018), lalaina74 (24th April, 2019), rokibar (22nd September, 2018)
  6. #4
    rob h's Avatar
    May 2011
    You could read the elv. J518
    A bit of work getting it out.
    You can load dump in avdi and get the 7 bytes.
    There should be a dealer key option, or key to dump.
    e8 transponders or org remote.
    Try this dump:
    http://www.digital-kaos.co.uk/forums...highlight=j518
  7. The Following 4 Users Say Thank You to rob h For This Useful Post:
    doctore (20th September, 2018), lion0304 (8th May, 2019), PocketHero (26th September, 2018), z786 (21st September, 2018)
  8. #5
    drugowaz's Avatar
    Mar 2015
    Lithuania
    So this is old type key or bcm2 key?
  9. The Following User Says Thank You to drugowaz For This Useful Post:
  10. #6
    z786's Avatar
    I know elv has to be read. But I was being lazy mate. I've done a6 2008 and 6 bytes and pin did the trick
  11. #7
    yugo45's Avatar
    Quote Originally Posted by z786 View Post
    2009 and up with 256kb module can not be done with 6 bytes only. Has to have EVL dump if you do not have key form delaer.
    If you buy key form dealer, you can learn it with 6 bytes.
    Also if EVL was replaced by Dealer in early models it will have module form 2009 and it will be same. Happen to me , had 2007 A6 and could not do it with out EVL dump.
  12. The Following User Says Thank You to yugo45 For This Useful Post:
    amigokola (22nd September, 2018)
  13. #8
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Its banana or smart key
  14. #9
    z786's Avatar
    Normally flip key mate
  15. #10
    super jumbe's Avatar
    Livingstone
    If you have smelecom tool follow this instruction mate go to lost key.
    Sorry getting file error I will come back soon.
  16. The Following User Says Thank You to super jumbe For This Useful Post:
    z786 (22nd September, 2018)
  17. #11
    PocketHero's Avatar
    Jun 2017
    Budapest, Hungary
    Quote Originally Posted by super jumbe View Post
    If you have smelecom tool...
    then you are damn rich... $5400 @ Aliexpress
  18. #12
    Livingstone
    This is the download pdf link it explains clearly how to program new key and lost keys.
    http://www.smelecom.com/down/VW%20IM...20function.pdf
  19. The Following 3 Users Say Thank You to super jumbe For This Useful Post:
    amigokola (22nd September, 2018), triak88 (24th September, 2018), z786 (22nd September, 2018)
  20. #13
    z786's Avatar
    Thanks buddy. I know the manual procedure just looking 4 short cut
  21. #14
    yugo45's Avatar
    There is no short cut for module after 2009 with 256kb file unless you buy key form dealer by VIN .
  22. #15
    Sep 2016
    Quote Originally Posted by yugo45 View Post
    Its 10min job when you change immo data in elv. When you have 6byte from ecu which is 1min, obd2 1-16 together to ignition on and can direct on the left side of dashboard. Next change immo data in elv and gearbox when automatic and prepare new key and learn it.
