MC9S12 Question Pin BKGD Broken
Results 1 to 3 of 3
    Feb 2018
    Mexico
    Default MC9S12 Question Pin BKGD Broken
    hello I have a question, yesterday I was reading an MC9s12XET512MAG
    and I broke the BKGD pin. But the microcontroller does not work.
    I read that the pin is only necessary to perform the microcontroller programming
    Can the BKGD pin affect the microcontroller no longer working?
    regards
    Dec 2009
    Maybe because you not broke Pin 26 (BKGD) but pin 61 (PH3) and if you wired the othe wires incorrect you maybe killed the MCU.
  3. The Following 2 Users Say Thank You to exe123 For This Useful Post:
    gandrade (25th September, 2018), nenadgorgi (25th September, 2018)
    Feb 2018
    Mexico
    Thanks for the reply
    I just verified the microcontroller can work without the BKGD pin and the truck is able to start the engine, however the pin is used by the OBD2 interface to be able to enter to diagnose the modules. I have repaired the PIN.
    This Thread is SOLVED
