Results 1 to 4 of 4
    May 2018
    Default Transtron ECU writing failed
    I was able to backup this Transtron ( chip 64F7058F) via Ktag(clone) but faild to write the file to remove DPF. Ktag software ask to select the original file to compare . I have two files saved and non of those worked.This is my 1st time playing with Transtron ECU. Have you guys experienced the same ?
    Jan 2018
    Jemen
    Yes, I had the same with Denso. Close this window with a "cross" and it should go further. Do not click OK.
  3. The Following User Says Thank You to oliva For This Useful Post:
    era007 (27th September, 2018)
    May 2018
    Quote Originally Posted by oliva View Post
    Thank you. It work
    Sep 2012
    can you upload your ktag read file thnx
