Results 1 to 11 of 11
Thread: w204 zgw repair
    Default w204 zgw repair
    need help to repair w204 zgw p/n a 212 900 67 24
    try to change mileage with vvdi and zgw went off i tried to write eeprom backup to car now zgw is dead completly now car canot connect to any module including the zgw
    any help is very much appreciated
    here is eeprom and flash read with vvdi prog from 9S12XeQ384
    Feb 2017
    Baltic
    I have set from another w204, but you need to code it to your car. What year is your car?
    Pass in PM after thanks + rep
  3. The Following 2 Users Say Thank You to mikkhh For This Useful Post:
    addgsm (27th September, 2018), XMEN004 (18th July, 2019)
    Quote Originally Posted by mikkhh View Post
    thanks car is 2013
    thanks a lot mate i use ur flash +my eeprom backup and it work fine
    i realy appreciate ur urgent help bro
    Default w204 cgw damaged
    Hi mates please if possible to repair dumps for w204 cgw?!
    Thank you in advance!
    Jul 2018
    When You can Change Mileage For W204 OR 212 207 Use Digiprog3 The Best Change Only With EIS
    Nov 2015
    HOLA AMIGO PUEDE DARME CONTRASEÑA PARA INTENTARLO EN MI COCHE GRACIAS
    Nov 2015
    Lo he configurado desde otro w204, pero debes codificarlo en tu auto. ¿En qué año es tu coche?
    HELLO FRIEND YOU CAN GIVE ME PASSWORD TO TRY IT IN MY CAR THANK YOU
  10. #9
    Feb 2017
    Baltic
    What tool you have to read/write cgw? I will take gateway from my car and read it out.
  11. #10
    Nov 2015
    VVDIProg
    CG Pro
  12. #11
    Nov 2015
