write support they will send you a connection.
I wrote and get file but cannot open it
Its .mht format.
If someone will open it then please paste here a screenshot
Its .mht format.
>>Genuine Winols, Swiftec, Ktag, Flex, x17<<
>Diagnostic, Chiptuning, Dashbord<
ashraf2000 (20th December, 2019)
AS far i know, there is possible to read and write using Ktag Ori, but checksums are not calculated so file is useless. Has anyone know any other tools that could read and write ems 2.3 sucsessfully?
Yes this is true. I have Ktag ori and support told me that i can read write but cannot calculate checksum.
Can someone else write to support for connection beacuse they send me only file that i atached on post before but for me there is no connection picture in file
Is there any news on EMS 2.3? I understand correctly that a ktag can read-write a dump, but there is no calculation of the checksum of the dump and there is no possibility to make changes?
Yes, exactly that what you tell.
No possibility to calculate cheksum= no posibility to make changes.
Can I read the memory from one EMS 2.3 (is it new, works well) and write it to another new ECU EMS 2.3? Any protection for the serial number or processor ID is present?
There is no possibility to clone this ECU - just checked with Dimsport
Since 21.05.2019 New Trasdata supports reading/writing EMS2.3 but not checksum
If you find my post helpful please hit Thanks button.
You can also hit Reputation button if you are kind enough.
Ols805 since v2.21 (2018-07-30)there is test checksum have not tested it
Some on have done adblue off TRW EMS 2.3 adblue off
https://r.tapatalk.com/shareLink?sha...7&share_type=t
Skickat från min iPhone med Tapatalk
Can you please show me the KTAG pingout?
Hi mates,
Can anyone help up with full pinout of this ecu please?
Thanks a lot
Hi To all,
Volvo TRW EMS 2.3 and 2.4 availble to Read/Write by Trasdata you need special cable if you dont want to open the ECU.
for ACM reading you need to open the ACM unit.
I read and write the Ecu/ACM now for a Time already and able to Remove SCR- adblue and DPF
so now you know.
all other tools cannot Read or Write that ECU/ACM for now
regards
alclot (16th March, 2021)
Dimsport Can write EMS2.3 will all necessary maps and flags for any DPF / EGR / SCR off.
Newer 2.4 main maps can be reflashed with chk too, but DTC still doesn't covered well and just can be emulated.
Cars & Tucks Stage-1-2-Eco / DPF EGR SCR with 10 years guarantee!
New solution development & custom tuning. Skype support - EngineCoders
thank you for this file, please pass
