Results 1 to 9 of 9
    trickydicky
    Guest
    Default Modifying a Neutrino image
    Hi all,
    I would like to improve a Neutrino image. Basically tidy up the multi event EPG if possible.. and am looking at obtaining the source somehow.
    Ive read about undreamboxfs. Is this the way to unpack an image? if so, how do I go about doing it? and where is it?
    Alernatively, anyone know where a Neutrino source is? or how to obtain one, or anyone got an image they can make available?
    I know I need a linux install, which isn't a problem..
    Cheers
    V.I.P. Member Donnie Darko's Avatar
    May 2008
    Doubtful you'll get the source code for neutrino,people have asked in the past but they have failed to get it.
    Dreambox Guru osborne82's Avatar
    Mar 2008
    any dreambox development forum
    Quote Originally Posted by trickydicky View Post
    Hi all,
    Cheers
    neutrino sources are in cvs follow the guid to build a dreambox image ull find neutrino in
    there to play with albeit a basic neutrino
    cheers
    osborne82
    Mar 2008
    Quote Originally Posted by osborne82 View Post
    cheers
    osborne82
    Not quite so basic, I have one here with a recompiled zapit that scans in 3 mins like the dbox one, not by editing the cables.xml which doesn't work everywhere, just going to enable the editing in the scanning menu so netid, freq and sym rate can be easily inputted as editing the scan.conf is a pain in the butt.
    full epg same as the dbox2.
    error free recording.
    normal service.xml and bouquet.xml so it accepts dbox2 files without poncing about.
    just needs some tidying up and it will be released.
    Administrator
    Devilfish's Avatar
    Feb 2008
    Hey Scruff...thanks for the update!
    Good to see you about!
    May 2008
    Quote Originally Posted by scruff1963 View Post
    sounds exciting i am very excided about trying this
    May 2008
    Is this the same as another neutrino being touted elsewhere?
    Checkout the RED stickies massive amount of info and effort been put into them.
    Administrator
    Devilfish's Avatar
    Feb 2008
    Yes, same image m8.
    May 2008
    I see the beta has been released and and looks nice to
