Results 1 to 7 of 7
    Aug 2018
    Default Opel Astra 1.7CDTI 101HP Need EGR OFF EDC16C39 1037374425
    Hi friends need egr off Opel Astra 1.7CDTI 101HP EDC16C39
    SW:1037374425
    Please good solutions
    READ OBD BY MPPS V18
    johak's Avatar
    write this........
  3. The Following 2 Users Say Thank You to johak For This Useful Post:
    artureq3 (2nd October, 2018), konq100 (23rd January, 2021)
    Aug 2018
    Thanks friend good work
    Dec 2020
    Poland Warsaw
    Can I ask for a password ? Please.
    Dec 2020
    Poland Warsaw
    I found info about 6 maps. When I did 00 00 00 00 00 00 00..... (after 12 20 12 2A ) in flash the engine works fine (no DTC) with connected EGR and clogged EGR pipe. First map is at 068CA0, second 068D60, third 075FE0, next 0760B0, next 0C3CC0, last 0C3D90. I think, it is similar for other software EDC16C9 for Z17DTH engines.
    Aug 2020
    Birmingham,England
    here is the same file as above with egr off and checksum corrected
    try it
    no pass
    IF I HELPED YOU DON'T FORGET TO HIT THANKS AND REP
  8. The Following User Says Thank You to geedot187 For This Useful Post:
    motorfan1 (24th January, 2021)
  9. #7
    Dec 2020
    Poland Warsaw
    Thank you geedot187 for answer. I can not try your file on the car becouse the car has already gone. File above is a partially read. I have read by bdm. Thanks for help.
    the car has already gonethe car has already gone
