Page 3 of 5 FirstFirst 12345 LastLast
Results 31 to 45 of 75
  1. #31
    Aug 2015
    Quote Originally Posted by 258 View Post
    full dump here
    many thanks for the dump. But do you have a full dump before erasing sectors 265 and 266? You did a full backup before doing this, right?
    Erasing these two sectors will destroy the filesystem, it will be rebuild after restart but many files are lost forever (i've figured out a non-destructive solution for LCN1.0/1.5 and thanks to another member of DK i know it works). The unit is a LCN2.0 but dump (the first and only one in my collection) looks like Nissan LCN1.0/1.5 with minor differences. But LCN2.0 seems to use another protection scheme than LCN1.0/1.5 so i cannot give you a code and the file containing the lock-counters for LCN1.0/1.5 is not available in the filesystem of your dump, thats why i asked for a dump before erasing both sectors. Are you sure this unit is using a pin code? Maybe it is connected to CAN-bus and paired to ECU or something like that and needs a CAN-Emulator. Do you know in which car this unit was build in? I will have a look at the firmware to solve this interesting riddle if i get some free time, but this is a time comsuming process so please be patient.
    wbr
    EDIT: Device 7612033031 is a Nissan LCN2.0A and needs CAN Immobilizer emulator
  2. The Following 3 Users Say Thank You to Thinner For This Useful Post:
    258 (7th January, 2019), irfa (4th December, 2018), masterskay62 (4th December, 2018)
  3. #32
    Default nissan lcn eu bosc
    please decode this radio nissan
  4. #33
    Aug 2016
    Tychy
    Hi lads,
    just got unit LCN1 7 612 830 076 , i red code by martech, but radio not accept code .
    i did reset but still the same ,
    any suggestion ?
    Thx
  5. #34
    KARLOVE POŚLADY
    Hi Guys!
    Anybody can decode pin code from the sector 507?
    Radio was fully blocked by customer (10 times wrong pin code)
    Now radio start ( after reset 265,and 266) but i have no pin code.
    Thanks in advance!
    Regards:
    kredka
  6. The Following User Says Thank You to kredka74 For This Useful Post:
    Thinner (8th January, 2021)
  7. #35
    POLAND
    Quote Originally Posted by kredka74 View Post
    Hi Guys!
    Thanks in advance!
    Regards:
    kredka
    Code: 0955....
  8. The Following 3 Users Say Thank You to voltec For This Useful Post:
    kredka74 (18th August, 2020), masterskay62 (18th August, 2020), Thinner (8th January, 2021)
  9. #36
    KARLOVE POŚLADY
    Thank You!
    Working fine!
    Best regards:
    Kredka
  10. #37
    Aug 2015
    Hi experts,
    Kindly help with code for this radio:
    Serial 0262422
    Device 7513750018
    Date 13.03.01
    Thank you!
  11. #38
    Oct 2020
    Help with unlocking this device, the dump was restored by itself, but it is impossible to unlock
    7 612 830 093
    25915BH21B
    TBE523
    https://drive.google.com/file/d/1mbe...ew?usp=sharing
  12. #39
    smoggy's Avatar
    Apr 2009
    UK North East
    Quote Originally Posted by Voznyis View Post
    7 612 830 093
    25915BH21B
    TBE523
    try code 7120
  13. The Following 2 Users Say Thank You to smoggy For This Useful Post:
    irfa (11th November, 2020), masterskay62 (10th November, 2020)
  14. #40
    Oct 2020
    On the screen, contact your Nissan dealer and it is not possible to write the code
  15. #41
    Oct 2018
    you entered the wrong code 10 times
  16. The Following User Says Thank You to Mikle1 For This Useful Post:
    Voznyis (11th November, 2020)
  17. #42
    Oct 2020
    Mikle1, thanks to your dump, I restored mine, but there is a complete lock after deleting 265,266 sectors it does not turn on, see my working dump how you can remove the lock. Your mail is full could not send a message
  18. #43
    Oct 2018
    Erase sector 265,266
    after done it disconnect and reconnect power supply and wait 4,5 minutes .
  19. The Following User Says Thank You to Mikle1 For This Useful Post:
    Voznyis (12th November, 2020)
  20. #44
    Oct 2020
    Ok: devil:
  21. #45
    Jan 2020
    Помоги пожалуйста с магнитолой Opel Touch & Connect Bosch 7 612 830 141
