Results 1 to 10 of 10
    Sep 2010
    Nowy Sacz (Poland)
    Default Kia Carens 2.0 CRDI DPF OFF
    Can anybody remove DPF in Kia Carens 2.0 CRDI 2008 year?
    BOSCH NR: 0 281 013 072
    KIA NR: 39116-27485
    ECU Safe didn't work with this car.
    Thanks in advance
  2. The Following 2 Users Say Thank You to sstuning For This Useful Post:
    dziongas (7th January, 2015), sparedes (5th October, 2018)
  3. #2
    maxtdi's Avatar
    Nov 2010
    Slovakia
    Default dpf off
    file without cks.....
  4. The Following 2 Users Say Thank You to maxtdi For This Useful Post:
  5. #3
    Member ESER's Avatar
    Jun 2010
    Ukraine. Odessa.
    Here with the corrected control sum
  6. The Following User Says Thank You to ESER For This Useful Post:
  7. #4
    Jun 2010
    Ukraine. Odessa.
  8. The Following User Says Thank You to ESER For This Useful Post:
  9. #5
    Top Poster crackintosh's Avatar
    Jul 2009
    Chisinau
    Can you tell me how did you calculate CRC ?
  10. #6
    Sep 2010
    Nowy Sacz (Poland)
    Ok, today i write file to ECU, and tell You how them work.
    Checksumm calculated with WinOLS?
  11. The Following User Says Thank You to sstuning For This Useful Post:
  12. #7
    Sep 2010
    Nowy Sacz (Poland)
    File is identical with ECUSafe removed - car is in service mode, MIL was on.
    After and before disconnect particular pressure sensor, i have error - particular filter pressure.
  13. #8
    Nov 2010
    france
    WHAT IS THIS DPF PLEASE
  14. #9
    calin_bm's Avatar
    Jan 2010
    near civilization
    how about to share with us if the car worked or no? i have tucson fap and i'm still searching for some info...
  15. #10
    Oct 2018
    BUENA BUENA EXCELENTE CASO NECESITESAYUDA ME AVISAS
