Results 1 to 4 of 4
    May 2018
    Default Renault Trafic EDC17c42 read/write with Kess by Obd?
    Hello,
    I have a question:
    Is it possible to read and write Renault Traffic EDC17C42 with KESS clone by OBD?
    I read through the kess injectors of this car via OBD.
    ECU ID from Kess:
    HW: 1754R
    SW: 1037521429
    VIN nr.: VF1.......................................
    SW ver.: 2011R
    Spare:
    Engine:
    HW Ver.:
    SW upg.: 2437R
    Installation:
    Regards
    Wysłane z mojego SM-G965F przy użyciu Tapatalka
    Nov 2012
    CRO
    Kess says it should be possible. But i suggest you to put the ECU on bench and read/write it in boot mode - that's the most secure way.
    carmageddon's Avatar
    Apr 2010
    Italy
    you can R/W this ecu with boot but is very difficult, by obd is possible R/W without problem.
    May 2018
    Quote Originally Posted by carmageddon View Post
    Ok, thanks.
    Injector codes will be lost after flash?
