Results 1 to 15 of 15
    Jan 2018
    Default Vw Passat 2008 BMR dpf off
    hi. i need dpf off to vw passat 2008 2.0 170hp BMR. i need to this file because i thing it has stage1. i am not sure. thank you
    Apr 2016
    here you go!
    pass pm, dont forget thnks+rep
  3. The Following User Says Thank You to eculevel For This Useful Post:
    BavarianBMW (8th October, 2018)
    Jan 2018
    please send me the password
    Jan 2018
    i put the map. everything is ok but i have dpf light on dashboard
    HIC's Avatar
    You solve your problem?
    Jan 2018
    not yet. i try to reset all with original map but still P2002. i try regenereting but nothing
    HIC's Avatar
    Send ori file
    clear all dtc
    make dpf renew.
    if mod file is good all must be work fine.
    if you need new mod i m here for help
    Jan 2018
    i reset everything. but still p2002. i try regenereating with ori but still light on.
  10. #9
    HIC's Avatar
    Make a picture with fault all designation
  11. #10
    Apr 2016
    look parameter dpf % and temp with diag, if its ok the problem is just the reset
  12. #11
    Jan 2018
    i have in options just ecm carbon replacement. everything is reset but after i clear P2002 in 2 seconds appear again. it is possible to not be original dump?
  13. #12
    HIC's Avatar
    Test please this mod and report
    Send ori file
    clear all dtc
    make dpf renew.
    Send mod and test
    No CS Pss in PM
    Report please
  14. #13
    Jan 2018
    send me pass please
  15. #14
    HIC's Avatar
    Check you box
    don t forget thanks and rep
    hope it s working for you ;this is working solu
    Quote Originally Posted by BavarianBMW View Post
    send me pass please
  16. The Following User Says Thank You to HIC For This Useful Post:
    BavarianBMW (9th October, 2018)
  17. #15
    Jan 2018
    problem solved. thank you
