Hello, i have problem with zafira EDC16C9 1.9DTH 120Hp the DPF and Sensors are removed and the car is in limp mode 2000rpm.
i found original file but i connot remove corectly DPF and sensors. So if any one have some solution.
Launch X431, BOSCH KTS200, FGTech Galleto 2, MPPS , Piasini , BDM100 , KWP2000, Lexia, Can Clip, Compact C4, Omega Programer ... soldering iron
try this mate
send me pm if it is good
kind regards
if this not work i have 100% working solution
i'm at home already i will test tomorow
Xtuner solution not work at all limp mode at start.
Here u go, pass pm.
Don't forget buttons after test
Disconnected (11th October, 2018)
thank you for help mancioks solution working i tested it.
