Ford Transit 2.4 2007 EGR advice
Results 1 to 4 of 4
    Oct 2018
    Wales
    Downloads
    Uploads
    Question Ford Transit 2.4 2007 EGR advice
    I have a jumbo transit 2007 2.4 with the egr removed and blanking kit installed.
    Failed the last MOT due to power train codes relating to the egr being removed.
    I need to fully remove the egr from the ecu.
    I have several options to try but with no experience with the transits ecu I would like some reassurance before wasting time...
    Hoping to use an obd option rather than a bench flash.
    i have a copy of EGR PRO Remover, but isit compatible with the visteon ecu ?
    i have a kess v2 and willing to find and edit the EGR values, but Iím hoping someone already has the HEX values I should be looking for? (Or will the egr pro remover software automatically find generic egr values and remove?)
    i donít want to remove and be left with New/other codes relating to the egr.
    i believe the current file on the van is a stage 1 remap by a local business but not sure will have to check against a untouch version.
    Any help on the mk7 2007 2.4 transit EGR would be appreciated.
    considering a cheap bundle of ford files on eBay but I doubt it will give me the information I want.
    Dec 2017
    24
    Downloads
    Uploads
    Best is read the file with Kess as youíve mentioned
    Upload the file on here and someone will delete it for you and upload back
    So all youíve to do reprogramming back
    Your stage 1 Mapp still be there
    Oct 2018
    Wales
    Downloads
    Uploads
    Quote Originally Posted by Happy786786 View Post
    thanks for your reply
    i will upload a copy of the current file tomorrow, fingers crossed someone can help.
    Do you know if the egr remover tool or similar like ecusafe just find generic values for the fault codes and remove? Or am I missing something more specific to the Ford/ecu?
    Any info would be great
    T
    Oct 2018
    Wales
    Downloads
    Uploads
    Relevant info
    Visteon DCU102
