Results 1 to 7 of 7
    Apr 2015
    Default Citroen C1 Starts and dies
    Hi everyone have a citroen C1, car starts for a second and dies, has a flashing stop light on dash.
    fault code "Fault in communication with the immo control module"
    brend's Avatar
    Oct 2015
    Same where
    Quote Originally Posted by sirjay View Post
    Fault NR. code?
    keygargoil's Avatar
    read immo ecu and key data il sync it for you
    on these c1 aygo peug 107 models they will always start and die if the key isnt recognised are you using genuine chip, image gen chip via tango etc or tpx 2
    keygargoil's Avatar
    ps if you have a gen key try this
    side lights on disconnect battery for 5 mins then reconnect then bridge obd pins 4 and 13 then turn ignition on for 30 mins this will relearn sync codes key immo and ecu
    if the battery has gone flat and booster has been used without sidelights on immo will have lost its check sum sometimes a 30 min relaearn does it but be prepared to have to pull the ecu and immo out
    battery vaultage must be above 12.5 v
  5. The Following User Says Thank You to keygargoil For This Useful Post:
    sirjay (12th October, 2018)
    Apr 2015
    Quote Originally Posted by keygargoil View Post
    Where is the immo located?
    rob h's Avatar
    May 2011
    Start with telling what happend!
    You dont just loose synch.
    They ask you what dtc?
    Then you search on d.k. this dtc.
    Or search on Aygo!
    Then you will come a cross the immobox partnumber.
    Try googling that, and it will guide you to the immobox location.
    There are ennough problems and solutions out here!
  8. The Following User Says Thank You to rob h For This Useful Post:
  9. #7
    Apr 2015
    I mannaged to get the car to work shop and strip dash to get to immo, can please help me the immo ecu synch
