Results 1 to 3 of 3
    Jul 2017
    Default Ford Transit 2001 IMMO PROBLEM
    somebody try lerning key with OBD.
    I open unit and read eeprom. EEprom files look crazy. Where is problem ? EEPROM file is crash ?
    Jul 2017
    ..file here
    Oct 2017
    UK
    Default immo
    Hi, could you help with the attached eeproms. The old file in the rar file has a corrupt eeprom but the immo is still there as the van runs, but smokes like an old chimney, could you locate the immo in the old file so i can put it in the new file or could you help with putting it into the new file. Both reads are from identical ecu's.
    Thanks.
