Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 48
  1. #16
    BusCan's Avatar
    Nov 2013
    Quote Originally Posted by publiperro View Post
    the car is in transport mode and there is no way to get it out that way.
    bcm used micro 70f3633 / 70f3634I bought used bcm and I try to program with opel tips after having virginized it with the io / terminal option, but it fails in the programming, I want to think that it is because the number of the vin is not the same, there is a way to change it.
    here is the dumps of the original bcm of the car with transport mode and the used one that is fine.
    Hi The two Dflash readings without deferens ?? Did you read both with ioterminal?
    Does your original file start the vehicle?
    What and the number of your BCM
  2. #17
    publiperro's Avatar
    Apr 2016
    Espaņa
    Quote Originally Posted by BusCan View Post
    If the readings are different, one is the original one that if the vehicle starts and the other is a used bcm, but the problem is that the original is in transport mode and doors, radio, etc. do not work and I want to adapt the used one , since if I pass the information from the original to the used one, the car starts but continues in transport mode.
    everything is read with io terminal.
  3. #18
    BusCan's Avatar
    Nov 2013
    OK Do you have access to SPS online?
  4. #19
    publiperro's Avatar
    Apr 2016
    Espaņa
    if i have access
  5. #20
    BusCan's Avatar
    Nov 2013
    Default Dflash virgin
    if i have access
    Here Dflash virgin
    Teste and repor pls
  6. The Following 13 Users Say Thank You to BusCan For This Useful Post:
    Adask83 (25th October, 2023), calit10 (30th October, 2023), djicek (26th January, 2021), ecuauto (21st November, 2021), ecumix (5th March, 2021), jacostanzo (21st September, 2021), momo59 (4th December, 2023), moow (22nd February, 2024), nemena (15th October, 2021), Nikola1309 (4th February, 2022), publiperro (18th December, 2020), subas (8th February, 2024), zoko (23rd March, 2022)
  7. #21
    publiperro's Avatar
    Apr 2016
    Espaņa
    Here Dflash virgin
    Teste and repor pls
    Mars or Wednesday I will make the car, when I programmed it I will tell you, thank you very much, if it works you have saved my life with this car, which is driving me crazy, thank you very much again, I tell you when I programmed.
    thanks buscan.
  8. The Following User Says Thank You to publiperro For This Useful Post:
    BusCan (19th December, 2020)
  9. #22
    BusCan's Avatar
    Nov 2013
    thanks buscan.
    Thank you normally you have no reason for it not to work. For your information I'm not saving anyone it's god who saves it's creature
    Keep us informed
  10. The Following User Says Thank You to BusCan For This Useful Post:
    publiperro (23rd December, 2020)
  11. #23
    publiperro's Avatar
    Apr 2016
    Espaņa
    Keep us informed
    Everything has gone to perfection thanks to your help and if you have saved me by virginizing my bcm, thank you very much.
    By the way, did you virginizar with sps in the option to restore a new unit or do you have a program to make the unit virgin, again thank you very much.
  12. The Following User Says Thank You to publiperro For This Useful Post:
    BusCan (24th December, 2020)
  13. #24
    BusCan's Avatar
    Nov 2013
    Thank you for the feedback it is a blank file following a relentless research language I'm happy for you it's your Christmas presents :
  14. The Following User Says Thank You to BusCan For This Useful Post:
    publiperro (29th December, 2020)
  15. #25
    Mar 2016
    Here Dflash virgin
    Teste and repor pls
    password please
  16. #26
    BusCan's Avatar
    Nov 2013
    Quote Originally Posted by djicek View Post
    password please
    Poste original dump
  17. #27
    Dec 2010
    Hello friends, I need help for full virgin file, after battery flat car goes crazy, I made clone with io terminal to a new bcm no solve, problem in original dump.
    I try to adapt the used one no succes, in attach dump from used bcm to put in virgen mode. Thanks
  18. #28
    BusCan's Avatar
    Nov 2013
    Quote Originally Posted by jacostanzo View Post
    Hi Did you solve your problem with the meriva?
  19. #29
    I have; Opel Meriva B (S10) 1.4i 74kW (100ks) A14XER E5 2010g
    BCM: Delphi 13350882 13349932 (with LOCKED MCU: NEC D70F3380-M2 QFP144) and not possibe to read any original memory.
    When I use "DFlash_vierge.rar" file in combination with any of the 3 attached files, SPS encoding does not pass.
  20. #30
    May 2018
    Ivano-Frankovsk
    please make it virgin
