Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 34
  1. #16
    Oct 2018
    When I try to read / write the 24c32 eeprom with PonyProg, I see the message "Missing Device".
    I checked all the connections and these are ok.
    Is the eeprom likely to be defective?
  2. #17
    Feb 2010
    WALES
    Quote Originally Posted by vasilika View Post
    Very unlikely, check com port and make sure chip is free from flux
    wbr
  3. #18
    Oct 2018
    I used exactly the same steps for reading / writing the eeprom as in my posts above and then it worked smoothly in my first attempt.
    Does "ERROR 02" refer to eeprom problems?
  4. #19
    Nov 2010
    Check components near 24с32. Maybe you broke something when I removed the EEPROM.
  5. The Following User Says Thank You to simplus For This Useful Post:
    Ihor1 (27th December, 2018)
  6. #20
    Oct 2018
    I did not extract the eeprom, but I used the method in this tutorial: https://www.youtube.com/watch?v=AVL6bB-zVP8
  7. #21
    Oct 2018
    I used these methods for the first time in my life and worked from the first try.
    Is it the luck of the beginner?
    Anyway this is my third attempt and it's over with luck ...
  8. #22
    May 2018
    Lvov
    Hi) help my please radio code vwz1z2g3079321 thanks)
  9. #23
    Nov 2020
    merhaba
    aşağıdaki dosya için kod yardım edebilirmisiniz
    teşekkür ederim
  10. #24
    Dekster's Avatar
    Dec 2012
    POLAND
    Quote Originally Posted by kguntay View Post
    merhaba
    teşekkür ederim
    Please post in English
  11. The Following 2 Users Say Thank You to Dekster For This Useful Post:
    masterskay62 (12th September, 2021), shooting (11th September, 2021)
  12. #25
    Nov 2020
    Merhaba
    , bu dosyadan şifreyi çıkarabilir misiniz
    teşekkürler
  13. #26
    Nov 2020
    Quote Originally Posted by Dekster View Post
    Merhaba,
    Lütfen İngilizce yayınlayın
    Merhaba
    teşekkürler
  14. #27
    Feb 2010
    WALES
    Merhaba
    teşekkürler
    Use English ONLY here!!!
    wbr
  15. #28
    Mar 2024
    RDC 300
    vwz2z2g1953299
    Help with code pls!!!
  16. #29
    Mar 2016
    Quote Originally Posted by repzy View Post
    RDC 300
    vwz2z2g1953299
    Read dump............
  17. #30
    Mar 2013
    Random
    Hi!
    Please code for rcd300.
    THX!
