Results 1 to 9 of 9
    Jun 2009
    Default A4 EDC17C74 lost power in high rpm
    Made my first EDC17C74.
    But have problem from 2900 rpm that the torque drop down. (yellow in the mod log)
    The torque in log does not match to the file from 2500rpm upwards.
    Had a performance hole 2900-3000 and from 3700-3900.
    Maybe i missed a torque limiter, but tried serveral changes but don`t find the problem.
    Can give me anyone a hint, please
    Aug 2012
    Quote Originally Posted by chli1976 View Post
    search this
    AccMon_trqMaxEng_C
    and check egt on !
    Tuning Cars and Trucks, Immo off , DTC delete, DPF off
  3. The Following 2 Users Say Thank You to icezero2010 For This Useful Post:
    AVDigitale (21st October, 2018), chli1976 (21st October, 2018)
    Jun 2009
    I have logged EGT, with this injection qauntity no restriction
    Must look for AccMon_trqMaxEng_C
    Do you have a C74 Damos, if yes send me infos and price
    Aug 2012
    use c64 is ok to find all !
    than take a look oil temp or intake temp
    and when u check your log u see u get only 60 mg injection
  6. The Following User Says Thank You to icezero2010 For This Useful Post:
    Jun 2009
    I know that i got only 60mg in this rpm`s but i don`t know why, will try your options.
    In my log is log from ori and from mod, there are two tables.
    Do you have a look in the mod table ?
  8. #6
    sdtsedat's Avatar
    Jan 2015
    Belgium
    This one....
    regards,
    Sedat Garip
    Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
    Diesel + petrol All cars
    Manual Adblue dpf egr Opf tested working solutions
    Belgium
    With Kind Regards,
    Don't forget hit thank button if i helped.
  9. The Following User Says Thank You to sdtsedat For This Useful Post:
  10. #7
    Aug 2012
    you can change the value what i write or the axis from iq maps scale down both work
    3c02aa i´m not sure but i think its correct adress
  11. The Following User Says Thank You to icezero2010 For This Useful Post:
  12. #8
    Jun 2009
    Quote Originally Posted by icezero2010 View Post
    Bought a damos now, but does not match in this area 100%
    But 3c02aa is x-axis (rpm) in AccMon_tiShOffOvrRun_CUR
    I think AccMon_trqMaxEng_C is on adress 3C02BA or 3C02BC
  13. #9
    Aug 2018
    Nederland
    Default 04L906026A_1974 MOD (ecuworks)
    pleas pm for password and thanks my
    no spam in sigs !!!
  14. The Following User Says Thank You to ecuworks For This Useful Post:
    chli1976 (22nd October, 2018)
