Results 1 to 7 of 7
    Apr 2017
    Default dpf egr prb citroen c5 x7 2008
    hi my friends sava? i have a citroen c5 x7 with problem of egr and dpf (lack of power) after dpf and egr off
    dcm3.4
    no dtc but lack of power
    solution plz
    thanks in advance
    sorry for ły english
    May 2017
    How someone can help you without file?
    HIC's Avatar
    Quote Originally Posted by ayoub laghrissi View Post
    solution plz
    thanks in advance
    You must have no fault to send file into ecu.
    Rewrite ori file and make fap renew ;when you have no fault in this time you can send mod file.
    You have make FAP off with ADS ?
  4. The Following User Says Thank You to HIC For This Useful Post:
    ayoub laghrissi (22nd October, 2018)
    Apr 2017
    yes with ads and winols .I Rewrite ORI FILE WHEN I MAKE THE DIAG DTC: p1417
    Quote Originally Posted by HIC View Post
    Apr 2017
    Default THIS IS THE ORIGINE FILE
    PLZ HELP THANKS IN ADVANCE
    Team dz's Avatar
    Apr 2017
    ALGERIA
    Default here this dpf off Egr off
    here this dpf off Egr off .
    This solision is good .
    password pm
    DPF / FAP / EGR / SCR / NOx / TVA FLAP .. etc
    Do not forget to press the button thanks and reputation
    # Algerian #
  8. The Following User Says Thank You to Team dz For This Useful Post:
  9. #7
    Apr 2017
    thanks broo
    Quote Originally Posted by Team dz View Post
    password pm
