Results 1 to 13 of 13
    Northern europe
    Default Audi A3 8P - Dash Pinout 32pin Blue
    Hello.
    Does anyone have a pinout for the Audi A3 8P dasshboard ? 32 Pin Blue connector.
    According to Elsa it should be :
    +12V on pins 1,2,18
    Ground on pins : 3,4,19
    Connected but cluster does not power up.
    Cluster : 8P0 920 931T.
    Tried to read conf and immo data in the car but FVDI tells me I need good key and it will not read.
    Any idea welcome.
    Thanks.
  2. The Following User Says Thank You to jaxone For This Useful Post:
    argegsm (17th March, 2022)
  3. #2
    brend's Avatar
    Oct 2015
    Same where
    Press magic button.........
  4. The Following 107 Users Say Thank You to brend For This Useful Post:
    Alejandroluli (29th April, 2020), Alek2012 (14th October, 2024), AleXPaiN (17th June, 2024), ampibali (4th November, 2020), andree90 (19th April, 2023), antwnhszr (8th December, 2020), Arek1965 (10th February, 2025), Ashraf786 (10th July, 2023), asliyucegsm (5th June, 2023), azoki981 (28th December, 2022), blackbeard10 (20th February, 2021), boxsport (25th October, 2022), buddycz (18th March, 2020), BusCan (21st November, 2020), Chupsy (25th November, 2021), Col19 (19th April, 2023), crisvenua2 (1st September, 2020), Daniel krenz (17th July, 2020), dawidhubert (3rd July, 2020), denis1hr (7th November, 2023), dexter321 (5th November, 2020), dritindiag (29th October, 2021), E82 (10th October, 2022), ecarruda (13th July, 2024), EdekW (22nd February, 2023), eeprom241 (9th January, 2024), Elektrik001 (3rd April, 2024), eliaslynda (12th July, 2024), elsatri (16th December, 2022), Fabian Luque (19th February, 2021), FlameFenix (17th August, 2023), funkyby (3rd November, 2022), gvpdwsbbyuji (10th July, 2020), hmagga (9th June, 2021), hsnlpy (25th April, 2024), iren71 (11th July, 2020), Ismael2020 (17th August, 2024), Jacob6969 (22nd August, 2024), jarbo3a (31st December, 2023), jarecki55 (15th February, 2023), jaxone (25th October, 2018), jcdiag (26th October, 2021), jjrp255630 (16th October, 2023), jkubp (21st June, 2024), karned (25th February, 2022), Kitt17 (15th November, 2023), klesk1986 (5th March, 2020), klonone (11th October, 2019), kral06060 (16th December, 2019), MahoJohn (21st December, 2023), majster10 (18th November, 2022), malugo (20th July, 2020), maxim57 (28th November, 2022), meganegro (15th December, 2022), mikajna (10th June, 2021), mike870 (14th May, 2020), misamix (21st June, 2022), MOBILTRONIC (22nd February, 2020), MrDudeCastro (28th December, 2023), Mrpiston (3rd January, 2023), nelsoncaseiro (22nd December, 2021), nesko0707 (17th May, 2024), P80TechGarage (1st December, 2023), padrtak (28th September, 2024), paulolad (18th August, 2021), PAVLOS2 (15th March, 2023), Pedro Poland (29th January, 2021), pietrak (28th March, 2022), pispes (30th January, 2020), popov (14th June, 2022), powerelectricpl (22nd February, 2021), pundravac (11th April, 2021), R-Tech (26th August, 2019), rolandk (28th February, 2021), ruemzaigc (20th January, 2024), scoot (28th January, 2021), shortys shaker (7th November, 2019), silvarog3r (29th April, 2025), sopomarius (20th July, 2020), Sotirov (28th August, 2023), spoool (3rd January, 2024), srzar (24th September, 2024), tdipowa (19th February, 2023), TeiS (2nd July, 2024), temur38 (25th March, 2021), tony59 (29th November, 2023), urcarpc (20th March, 2024), vdiag (4th July, 2021), volodin69 (19th December, 2021), Weasel3 (1st January, 2021), Willinickersen (5th June, 2020), willyboy28 (13th April, 2022), wowa557 (17th November, 2023), xdamdamx (28th January, 2020), yasser (6th August, 2021), Yhoni (3rd December, 2021), zeljolaki (10th November, 2021), zi0m3k (18th January, 2021), zmsautogas (2nd January, 2023)
  5. #3
    Northern europe
    Thanks but this is exactly the pins I mentioned , not working.
    When connected in the car it powers up, but on bench nothing
  6. #4
    brend's Avatar
    Oct 2015
    Same where
    If look this diagram ,location only +30 and -31 and +15 just empty.
    So.....for power up need can comunication.
  7. The Following User Says Thank You to brend For This Useful Post:
  8. #5
    Northern europe
    Quote Originally Posted by brend View Post
    You are right so no joy reading this on bench by CAN then.
  9. #6
    Jun 2018
    Quote Originally Posted by jaxone View Post
    You need can wake up by gateway .....
    Pin 5 on cluster too pin 13 on gateway
    But you doesn’t can read immo... FVDI Tell you ,, security acess failed“ because you have no working key installed
    Tell me what is your problem, maybe I can help
  10. #7
    Northern europe
    I need to swap old cluster (without DIS / MFA) with new white cluster.
    I can read all info from old cluster but I can only read mileage from new cluster.
    Need to transfer immo data from old to new and re adapt keys.
  11. #8
    Jun 2018
    Okay, normally you can read micronas 3217g with Xprog then you can change immo data manuely and reprogram it.
    If I helped you, leave a thanks
  12. The Following 2 Users Say Thank You to J328D For This Useful Post:
    Alejandroluli (29th April, 2020), jaxone (25th October, 2018)
  13. #9
    Northern europe
    FVDI should be able to read this cluster while in the car...
  14. #10
    Jun 2013
    EU
    On adapted and full working car yes. In fact you should read the original cluster immo data to have a copy of it and be able to fill new cluster data with it.
    But to do it you will need to read micronas and eeprom as said by the other pal. Then you can merge all data in the new cluster, no need to adapt keys after that, just fit in car and start with the always keys.
  15. The Following User Says Thank You to morgano For This Useful Post:
  16. #11
    Dec 2017
    Use micronas Trick so you have Full Access in Bench
  17. #12
    Jun 2019
    Polen
    Heelo thanks for this magic pdf ;-)
  18. #13
    Sep 2020
    Thanks for the help.
