Results 1 to 15 of 24
    Oct 2018
    Default 2nd Transponders in new gen. VW Key
    Hello, yesterday I opened a new gen vw key (7N5 837 202 H)
    i damaged the transponder and now car doesn't start.
    My idea was, that I program a new transponder and put it in the exiting key (remote is working).
    My technical support says, that is not good, because then there are 2 transponder in the Key.
    But I think its no problem because the original transponder is damaged.
    What do you say? Can I do this?
    Sorry for my bad English
    Greetings
    Feb 2014
    Yep, if transponder is damaged(broken) it should be no problem to add another one. No interference should occur.
    Just in case - you can remove the broken parts or if not possible, then you can brake it a little more .
    Oct 2018
    Quote Originally Posted by autoTkey View Post
    okay thank you very much!
    Can I remove the Transponder? or will the remote not work after I did this?
    Oct 2018
    Here a picture
    Feb 2014
    For the remote on the picture - it seems some condensers or resistors are missing. If you are able to recover them, I think car should be able to start again.
  6. The Following 2 Users Say Thank You to autoTkey For This Useful Post:
    rokibar (26th October, 2018), yugo45 (28th October, 2018)
    Sep 2010
    remove the coil and replace with new trensponder .
    jodge's Avatar
    Mar 2017
    for what?
    Two capacitors are missing, not related to the tp part at all.
    Resolder the marked capacitor and the two pin where the capacitor are connected.
  9. The Following User Says Thank You to jodge For This Useful Post:
  10. #8
    Feb 2013
    you lost something
    Wysłane z mojego SM-G920F przy użyciu Tapatalka
  11. #9
    Oct 2018
    Quote Originally Posted by jodge View Post
    for what?
    for what exactly i should do this?
    I want to understand that before i do this haha
    thanks for your answers!
  12. #10
    lion0304's Avatar
    Oct 2014
    Quote Originally Posted by GermanCarKey View Post
    There are 2 missing capacitor. Try to replace these and will work.
    Value you need searching for
  13. The Following 2 Users Say Thank You to lion0304 For This Useful Post:
    bzkmatrix (6th November, 2018), rokibar (26th October, 2018)
  14. #11
    jodge's Avatar
    Mar 2017
    Quote Originally Posted by swq123 View Post
    you lost something
    yeah i saw that but as i say those are not related with the transponder. It will working without it
    the black thing is a transponder coil. vertically. The small black rectangle is the transponder + remote but those are working separeted.
    The transponder electronic need a coil + capacitor (resonant circuit) to power up the whole thing. Thats the reason why working the tp w/o battery.
    if you problem with the TP check and resolder all visble components. Coil, capacitor, blask stuff.
    So pls resolder the marked capacitor and the two black recatgle pin where it's connected.
    I was more badly damaged my first vag pin house remote. 10min later it worked again
  15. The Following 2 Users Say Thank You to jodge For This Useful Post:
    amigokola (29th October, 2018), narkeleptk (26th October, 2018)
  16. #12
    Oct 2018
    I cant resolder them because i cant find the lost things haha.
    i think the easiest way is to programm a new transponder and glue it in.....
    what do I have to consider?
    i would say i programm the TP individually and then stick it inside...
    so nothing can go wrong when programming with respect to the old transponder.
    Thank you guys!
  17. #13
    TeL200's Avatar
    Worcester UK
    Options
    If that was only working key:
    * Repair/replace damaged/missing components
    * Remove cluster and code new key on bench
    * Remove cluster and code new transponder on bench, (de-solder induction coil and place transponder in it's place)
    If have another working key:
    * Code new key by OBD
    * Code new transponder by OBD, (de-solder induction coil and place transponder in it's place)
    Auto Locksmith / Security Professional
  18. #14
    Oct 2018
    The iduction coil is the vertically black chip on the top, right? i thought its important for the remote too? so i cant de-solder it?
    is it a problem if i programm the new transponder and glue it in, without de-solder anything?
    I ask so much because i will learn this for the future, programm new key is too easy
  19. #15
    Mar 2017
    If program new key is easy...program new key. All the info you need is in the first few posts. It surprises me how readily professionals provide details to DIYers and the greater universe.
