Results 1 to 5 of 5
    credoline's Avatar
    Србија
    Default Passat PPD 1.2 dpf off problem
    Hi friends. I have Passat 2.0 TDI with engine ecu 03G 906 018 ER Siemens fuel injection PPD1.2. And i need to make DPF off. And i did it with Swiftec but... after 100 km on dashboard i get DPF lamp on. In engine ecu no DTC-s but problem exist. I have it dtc P2002 (Diesel Particulate Filter Efficiency Below Threshold). I am empty DPF and do it with diag procedure for new DPF and after that do it software in ecu with DPF off, but car come back after 100km. And now, if i do it reset DPF again, lamp goes off, but after 15 km lamp turn on but not go in safe mode. But obvious Swiftec solution is not good. Can someone make it good DPF off for me ?
    File is read via bdm points.
    Thank you
    Team dz's Avatar
    Apr 2017
    ALGERIA
    Default here dpf off dtc off
    Swiftec solution is not good with ecu PPD 1.2
    here dpf off dtc off !
    DPF / FAP / EGR / SCR / NOx / TVA FLAP .. etc
    Do not forget to press the button thanks and reputation
    # Algerian #
  3. The Following User Says Thank You to Team dz For This Useful Post:
    credoline (27th October, 2018)
    Sep 2016
    they fix dpf solution in ppd1.2 and works great..... Only cut switch with dtc.
    FILE SERVICE
    credoline's Avatar
    Србија
    Thank you but you did not send me password for file.
    Quote Originally Posted by Team dz View Post
    credoline's Avatar
    Србија
    I do not know when they are fixed. I did it before 5-6 days. And on their website dos not write switch solution. Now not even write that PPD is covered for DPF off in their module version 2.0.
    Quote Originally Posted by voltechcar View Post
