Results 1 to 10 of 10
    Feb 2018
    Mexico
    Default [SOLVED] Ford Escape 2008 all key lost, Help
    Hello, I have a Ford Escape 2008, the customer lost all the keys but I can not program them, I have tried with the FVDI clone, the IDS of ford clone, with the X300 Pro and with the key programmer AUTEL.
    I arrive at the process where we have to add the 2 keys in the switch but in the IDS it tells me that the keys were programmed but not programmed.
    Does anyone know where the keys are in this truck? to be able to read the eeprom and if someone helps me to add them directly in the memory DUMP.
    UPDATE
    On the board brings a memory MC9S12HZ256, I have the file of the EEPROM and the FLASH. Can someone help me with an immo off?
    Try to try the key with the Ford KeyMaker of Tango, but ask me for a 4kb file, since my EEPROM is 2kb.
    NEW UPDATE SOLVED
    I already programmed the keys for the Ford Escape, after many attempts I used TP33 transponders. Thanks to everyone for your support.
    Jan 2017
    USA ����
    What key are you using?
  3. The Following User Says Thank You to sleepyrz For This Useful Post:
    gandrade (30th October, 2018)
    Feb 2018
    Mexico
    Quote Originally Posted by sleepyrz View Post
    i tried with different transponder and nothing.
    droidwayne65's Avatar
    Aug 2015
    North America
    Quote Originally Posted by gandrade View Post
    If you have a passthru device, a $49 FJDS subscription solves lots of problems with programming Fords. It's saved me headaches quite a few times with "unprogrammable" Fords.
  6. The Following User Says Thank You to droidwayne65 For This Useful Post:
    Jan 2017
    USA ����
    thats not a valid answer to my question but ok lets try one more time
    what key are you using?
    blade shell with chip?
    flip key?
    remote head key with chip on board?
    what transponder is inside
    is it a 40 bit? 80 bit?
    oem chip
    cheap chinese garbage?
    does the car have any codes coming up?
    any weird behavior you noticed?
    you want help ?
    answer those
  8. The Following User Says Thank You to sleepyrz For This Useful Post:
  9. #6
    Feb 2018
    Mexico
    flip key?
    oem chip
    you want help ?
    answer those
    Sorry, and thanks for help me.
    Im using a Chinese garbage key, but only for the forge. but i change the transponder for a OEM TPX2 Carbon original from Tango programmer.
    i tried with id60 40 bits, id63 40 bits and id63 80bits too. the transponder its good quality, not the chinese chip.
    the customer lost all the keys to the truck, so I used the Chinese key to remove the forge from the ignition cylinder, that key I am using to open the switch on. but I removed the Chinese transponder, and I put the ones that the supplier for the OEM programmer Tango sells me, since they are of good quality
    The car when opening the switch turns on the light of the immo and flashes indicating that the key is not programmed, by using the IDS clone of FORD, I get into PATS Functions, I give it a reset, and I start the process of the 2 keys, So I do what he asks, and when he tells me that everything was a success, BUT when reading the transponder in the TANGO, they are still virgins. and when you open the switch on, it keeps flashing. try the X300 pro and the Autek Ikey 820, I completed it, but the transponder is still not written.
    According to the client, the truck had no problem, only that he lost the keys. Here the problem is that I can not program it in any way. Try also with the FVDI clone, and send me an error.
    Sorry for my previous answer, I'm somewhat desperate and answer without thinking
    UPDATE
    reading DTC´s
    i have maybe 2 important DTC´s, add picture.
  10. #7
    Aug 2015
    North America
    B1342 is the far more interesting code. Something is wrong with the Instrument Cluster. It's either misconfigured or defective. That there's also a B1600 leads me to lean towards defective. It's possible the transceiver is bad but that wouldn't explain the B1342. Try clearing the code, do another self-test and check whether B1342 returns. Maybe you can also try a PMI on the Cluster, but I think it's toast.
  11. The Following User Says Thank You to droidwayne65 For This Useful Post:
    gandrade (7th November, 2018)
  12. #8
    Jan 2017
    USA ����
    Yes we have seen bad cluster make impossible to program keys through obd
    You would need to do through eeprom for it to work I think
  13. The Following User Says Thank You to sleepyrz For This Useful Post:
  14. #9
    Feb 2018
    Mexico
  15. #10
    p1et's Avatar
    Oct 2013
    TP33 = ID63 80 bit and you said you tried it before?
