Results 1 to 2 of 2
    Member dlf's Avatar
    Jul 2009
    Default Ford Mondeo Mk2 Clutch replacement
    I am looking for a guide for a mondeo mk2 clutch replacement.
    I dont have the Haynes manual.
    I understand the subframe has to be removed , so I'm just looking for some pointers as to the order in which to remove stuff and
    what and more importantly what not to remove .
    Any help would be appreciated
    Apr 2019
    i know is's old thread but in case someone else needs to know, you dont need to remove the subframe, just undo the bolts on one side partially and on the gearbox side remove them, (support as necessary). that lets you squeeze the box out. have to unbolt steering shaft from rack to allow subframe to drop enough. afterwards, re-attach steering shaft before subframe is fully raised or it's a bugger to get back on. if it is a self-adjusting clutch, make sure it is in the right position before fitting.
    best wishes,
