Citroen C5 2003 mileage correction BSI+ dash, opinions...
Results 1 to 7 of 7
    Apr 2017
    Christchurch, NZ
    Default Citroen C5 2003 mileage correction BSI+ dash, opinions...
    Jaeger dashboard and Sagem BSI. I was stuck to complete the correction as the Digiprog 3 (clone) does nothing with the dashboard, however read and write the BSI. I was looking the right tool to do the dashboard. According to the warning in the relevant section of NYO if I apply 12V to the cluster while it is out of the car that will erase the MCU. If I'm right, that is what I just need because as soon I assemble it the BSI will overwrite the dash and that's it. Is there anyone tried this yet? Any comment on this theory would be much appreciated.
    galaxy0634's Avatar
    Jan 2018
    Namek planet
    Jaeger made hc08 mcu i think its easy to read with correct wiring diagram connection
    galaxy0634's Avatar
    Jan 2018
    Namek planet
    Apr 2017
    Christchurch, NZ
    Thanks, I just waiting for my UPA to arrive with snail mail, I wasn't sure if CArprog can do it or not so I ended up to order it. However the "self reset" theory doesn't work. I had two attempt. When the dash got external power it shows zeros but doesn't seem to changes anything in the MCU.
    galaxy0634's Avatar
    Jan 2018
    Namek planet
    You did cluster plug yes just like carprog i think clone tools dont work maybe it need original tools good luck bro
    Apr 2017
    Christchurch, NZ
    Cheers mate, the UPA is original. I don't think even original digiprog would work via plug on this car.... Anyway I have to wait until arrives...
    Apr 2017
    Christchurch, NZ
    Upa work like charm... well 50%. I have a spare dashboard, just in case. I tried that first and did not worked. I almost chucked away, but luckily I tried on the dashboard from the car. Anyway mission complete...
  8. The Following User Says Thank You to nagy592 For This Useful Post:
    adjee (1st March, 2020)
