Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 60
Thread: Vxdiag nano
  1. #31
    Newbie Str3atW's Avatar
    May 2016
    Canada
    Got the J-Link in the mail today. I can switch the protection no problem, but when i read the chip it's only FFFF. I've tried to write firmware provided in rar file, it will write no problem, then i secure back the chip, but when i remove power, it revert back to FFFF. Is there something i'm missing?
    Str3atW
  2. #32
    May 2016
    Canada
    When i first write, with chip unsecured, it works good :
    If i read back the file, everything is good :
    Plugging the device back, it won't start. And if i secure the chip, then it goes back to FFFF
    Str3atW
  3. #33
    Dunker's Avatar
    Yorkshire
    Surely a secured chip will read all 0xFF or whatever regardless of what is in there.
    V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
    IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
  4. #34
    May 2016
    Canada
    Just to make sure, after writing bin file and securing chip, then my vxdiag unit should become alive again right? Because it's not the case right now... Any idea what i could be doing wrong?
    Str3atW
  5. #35
    May 2016
    Canada
    And just to be sure i wrote this right, the chip shows FFFF after i unsecure it and read it back
    Str3atW
  6. #36
    May 2016
    Canada
    Ohhh.... I just realised that the bin file is not the STM32 file, it's the firmware file... So i really screwed up in writing this in the STM32... Anyone have a dump of a working STM32 for a GM adapter, or any other adapter for that matter?
    Str3atW
  7. #37
    DWT's Avatar
    Oct 2018
    Quote Originally Posted by Str3atW View Post
    Hello to my colleague in misfortune, there are now two of us here who have killed their VXDiag while trying to read.
    I read somewhere on the Internet the following about software manufacturers protect their products from reading with STM32 with just one bit, i.e. setting a tick in the box to protect the chip. It is impossible to read without removing a tick, but removing its contents of the chip is destroyed and only "FFFFFFF" is read. Accordingly, if you want to read the previously recorded, then do not put the protection of the chip. I checked, works.
  8. #38
    DWT's Avatar
    Oct 2018
    I would also like to find him, but so far all unsuccessfully. The only thing that comes to mind is that it can be written in support of VxDiag that the chip burned out, I soldered a new one and I need a file to program it. Maybe foolish and send. Maybe the money will request and make programming through Timviewer. But most likely they will not answer anything.
  9. #39
    May 2016
    Canada
    I'm probably gonna buy another unit and try again... And if it works, i'll send you a dump of it.
    Str3atW
  10. #40
    May 2016
    Canada
    Worst that's gonna happen, i'll brick another one :P
    Str3atW
  11. #41
    Member JareckiPL's Avatar
    Dec 2013
    You can unsecure stm, but it make mass erase. Is possible, to unsecure without loosing dump, but you have to look on vxdiag manager it can unsecure chip to write firmware without erasing bootloader, so is possible but not that simply.
  12. #42
    Jan 2019
    It is very interesting and please can anyone explain me what is the benefit compared to the VCX passthru driver?
    Edit:
    Ok, tested by myself.
    Passtru is also limited, with a VCX Nano IDS (Ford/Mazda) it is impossible to use Xentry.
    But i read in another forum VCX Nano VW (5054 Emu) work with Xentry.
    Reason for the errormessage is the VCXPT32.dll, the passthru driver from VCX.
    ::10002CB3:: C705 DC1C0110 00000000 MOV DWORD PTR [10011CDC], 0
    ::10002CBD:: C685 E8FDFFFF 00 MOV BYTE PTR [EBP-218], 0
    ::10002CC4:: E8 D96C0000 CALL 100099A2 \:JMPDOWN >>>: MSVCR110.DLL:memset
    ::10002CC9:: 8D85 D8FDFFFF LEA EAX, [EBP-228]
    ::10002CCF:: 50 PUSH EAX
    ::10002CD0:: 68 9CB70010 PUSH 1000B79C \->: Error License For Function: %s
    ::10002CD5:: 8D85 E8FDFFFF LEA EAX, [EBP-218]
    ::10002CDB:: 68 04010000 PUSH 104
    ::10002CE0:: 50 PUSH EAX
    My new question:
    Is there another "check" in the firmware that make it impossible to use a VCX Nano as a real passthru interface?
    ps > Sorry for my bad english
  13. #43
    Sep 2015
    Germany
    Hello guys, I have a problem with vcx nano it means that st32f407 is completely cleaned, after uploading GM dump or Ford still does not work, it seems to me that the problem is in external memory has some idea.
  14. #44
    Dec 2013
    Quote Originally Posted by tricore View Post
    Witam chlopaki, mam problem z vcx nano to znaczy ze st32f407 jest kompletnie wyczyszczony, po wgraniu GM dump albo Ford dalej nie dziala wydaje mi sie ze problem jest w external memory ma ktos jakis pomysl.
    You need to get bootloader, not just a firmware.
  15. #45
    Sep 2015
    Germany
    hello Jarecki PL and where I can download the bootloader.
