Is this the latest Nabilo image for the DM500?
should be here in the downloads
Digital Kaos - Downloads - Nabilosat Enigma1 DarkStar II - DM500
dm800-s=1.1 m triax motorised dish=titanium twin lnb
DIGITAL KAOS BEST SITE ON THE NET
please use the thanks button if someone has helped
Thanks guys for your useful posts re changeing 28.4e and 0.08w to 28.2e and 1w. A friend has the same problem. I can now pass on the useful information.
I got the same problem with Darkstar II I downloaded. Will try the image listed here to see if it is different
i will try this imaged and after i will cheak if work fine or not
Flashed this image onto Dreambox 500s clone, it says CCcam 2.1.2 is installed yet I cant see a CCcam.cfg file in the var\etc folder, is there anyway of getting one in here?Do you have to set up anythign special in order to connect to the Nabilosat server from the Dreambox through a router?
Hy if i put this new cam in my dm it dont start , i pickit up from nabilo server and installed it, but cam wil not startup.
What else must i do , to let run 2.1.3 .
Gr
hello, im new here.
i have darkstar 2 on my dm500...but my dm500 doesnt even work. its showing up "Darkstar 2" as a screensaver, but i cant restart the dm500 or do anything...do i have to type in a password or something
pls help me
does anyb ody know where i can get the captains channel list, and where does it go on the nablosat image??
Faster than Faster
I have the same problem. With this image CCcam 2.1.2 is installed [I think] but there is no CCcam.cfg in var/etc
Is there a specific reason that cccam is included in the image? I can't even get CCcam 2.1.3 to work on it!
Can anyone recommend me an image for the DM500? Is Gemini 4.60 the best?
I use Darkstar2 and it is fine, however you can use NabiloDMVMAXVAR 0.8 I found it very good
which image do i need for a new 500s im new to all this
thank you my friend
