Page 3 of 5 FirstFirst 12345 LastLast
Results 31 to 45 of 61
  1. #31
    Aug 2010
    Belarus
    this photo is from the top cover
  2. #32
    shooting's Avatar
    WALES
    Quote Originally Posted by budata View Post
    You can't just add data to these radio's... 1000% incorrect
    wbr
    Don't confuse "Standing on my Shoulders" with "Treading on my Toes" ..
  3. The Following User Says Thank You to shooting For This Useful Post:
    budata (21st February, 2020)
  4. #33
    shooting's Avatar
    WALES
    Quote Originally Posted by Serg1o View Post
    Ah ok, then very bad read, you need a good read to be unregistered.. read eeprom again
    wbr
  5. The Following User Says Thank You to shooting For This Useful Post:
    Serg1o (22nd February, 2020)
  6. #34
    Aug 2010
    Belarus
    Thanks, I did exactly the same dump, based on similar ones and it works!
    Security code is: Delivery State
    Solved! Today I tied the radio to the car
    Quote Originally Posted by shooting View Post
    wbr
    Thanks for your help, but the eeprom dump reads 100% correctly. I checked several times. ST24C32 is read by the Omega programmer.
    The dump is similar in structure to similar ones.
  7. #35
    shooting's Avatar
    WALES
    Pairing data was missing, 10000% bad read, maybe problem with chip,
    adding data like that will only work temporary, then when it tries to add channels etc.. it will fail.
    You will be back, I guarantee it... this radio is always misunderstood.
    I work with these at least 5~10 times a day...
    wbr
  8. #36
    Jul 2020
    ECU
    Hello, I need pin for CD30 Delphi Grundig.
    Thanks in advance
  9. #37
    shooting's Avatar
    WALES
    Quote Originally Posted by ecuburner View Post
    Thanks in advance
    Pairing PIN is in the car's Display not the Radio
    wbr
    Here set to Virgin, ready for pairing:
  10. The Following 2 Users Say Thank You to shooting For This Useful Post:
    ecuburner (9th May, 2023), Mankyro (9th May, 2023)
  11. #38
    Jul 2020
    ECU
    I have extracted PIN from display, radio was virginized from member shooting and with OpCom I have paired with the display!
    Job well done...
  12. The Following User Says Thank You to ecuburner For This Useful Post:
    shooting (9th May, 2023)
  13. #39
    Apr 2023
    With the 24c32 ory cd30.bin file, the process is ok, but the aux is gone, the aux is not working
    I will be glad if you help
  14. #40
    shooting's Avatar
    WALES
    Quote Originally Posted by ramboy View Post
    This is what happens when you use other peoples dumps in your radio.... lesson learned..
    Post your Original file if you kept it and we can fix it
    wbr
  15. The Following User Says Thank You to shooting For This Useful Post:
    ramboy (27th May, 2023)
  16. #41
    Apr 2023
    This problem arose due to reasons beyond my control.
    ​i can send the file like this
    https://dosya.co/yquw46oteorr/24c32_...0MP33.rar.html
  17. #42
    shooting's Avatar
    WALES
    File is set to virgin, is this the original file to the radio?
    wbr
  18. The Following User Says Thank You to shooting For This Useful Post:
  19. #43
    Apr 2023
    This is not a virgin file. I found it and threw it into the radio, everything was fine, but after that, the aux went
  20. #44
    Apr 2023
    I'm not doing this commercially, so I'm not very dominant, but I would be very happy if you could help.
  21. #45
    shooting's Avatar
    WALES
    It's 100% virgin, and guessing not yours, this is why we need the radio's ORIGINAL dump from it.
    wbr
  22. The Following User Says Thank You to shooting For This Useful Post:
    ramboy (28th May, 2023)
