hello,
please need pin code from cd30 grundig&delphi
24c32
497316088
13263052
GM0D31
thanks and regards
hello,
24c32
497316088
13263052
GM0D31
thanks and regards
HELP == thanks + reputation
code 0265..........
Codekuba (3rd November, 2018), masterskay62 (3rd November, 2018), petronijul (3rd November, 2018), smoggy (3rd November, 2018)
pin 0265.......
shooting (6th November, 2018)
Yes, but I want to Log out this radio. tech2 does not want to log out the radio with this pin.
bogege (3rd November, 2018), Codekuba (3rd November, 2018), dantetimoc (8th May, 2020), rafal (3rd November, 2018)
Pin from you dump : 0265
What you want to do ? Do you want to change the old player ?
If the dump are from the new player, first time you have to make virgin you display.
Before to remove the actual player you need to virgin the system (player + display) : go with Opcom or with Tech2 on actual player, go to programming and select Deactivate anti theft protection.
After this step on you display you appear Radio Safe, Display Safe.
Now you can install the new player and go again on Programming and select Activate anti theft protection.
Before to activate the anti theft protection be sure that on display and on player you have the same settings on MID Speed CAN configuration.
Good look !
Dump is from a new radio. The old just popsulo. I will try to upload the batch from a colleague above and see.
What was happened with the old one ? was unclear for me ...
Let me know if you cannon solve the problem and I will offer you support ...
Codekuba (5th November, 2018)
Sorry for hijacking the thread...
I've looked around here and i also need the code for this stereo.
I see you talking about dump some information so you can get the code.
How can i get that "dump"/info? Is it enough for you to get the code?
I switched the stereo, the original broke and bought one used but it asks for code.
Thank you in advance for your time and once again sorry.
