Page 15 of 19 FirstFirst ... 510111213141516171819 LastLast
Results 211 to 225 of 325
Hybrid View
    Mendoza, Argentina
    Tanks, Form Argentine
    al70's Avatar
    Nov 2017
    Éire
    i can't connect to volvo's, any solution ?
    Dec 2014
    PL
    Quote Originally Posted by al70 View Post
    Hi.
    You should be more precise. What Volvo? Cars or truck? Which year of production? What type of PCB do you have in your tester? . V 3.0 V 6.0, 8.0 9.0?
  4. The Following User Says Thank You to Mario6 For This Useful Post:
    al70 (23rd January, 2020)
    al70's Avatar
    Nov 2017
    Éire
    Sorry mario, i have 2016 cpd, it's a double pcb with nec relays, it connects to everything i've tried so far, ford, vag, psa, but i tried 2009 volvo v40 and 2011 volvo s60 D3 and no communication, any input would be appreciated, maybe i have to rework obd plug, cheers, goodluck.
    Dec 2014
    PL
    The reason for the lack of connection may be a bad PCB V 8.0 / 6.0 or 9.0. The 2016.0 software is also faulty and may also cause a connection failure. You can still try wow wurth 5.008.2 ML or DEL / AC SW 2014.3.2 MD Final.
  7. The Following User Says Thank You to Mario6 For This Useful Post:
    al70 (26th January, 2020)
  8. #6
    Jan 2020
    Thankyou for this
  9. #7
    Nov 2017
    I can't update the ds150e firmware. Throws an error message. 2015R3 and 2016 not working, it also wants to upgrade the firmware. What is the solution?
  10. #8
    Dec 2014
    PL
    Quote Originally Posted by pinterto View Post
    What firmware is currently in your tester? Just stay with the old FW. Copy / paste old fw to a folder in a new SW. For example, paste old 1423 instead of new 1513. In the new FW, change the name and leave it in the folder too. (Firmware1513) The software will use "Firmware" without any additional name.
  11. #9
    Jan 2020
    Why i cant download it its soo annoying i was even sign in and register and still cand download wt hell...
  12. #10
    Jul 2019
    Thanks! Voy a probar
  13. #11
    Jan 2020
    I probably bricked my delphi, it wanted to update firmware i stopped it now when i plug in into car the lights are red and i can't connect, do you know fix to this?
  14. #12
    Dec 2014
    PL
    [QUOTE = Javado; 3780906] Prawdopodobnie zamurowałem moje delphi, chciałem zaktualizować oprogramowanie, zatrzymałem je teraz, kiedy podłączam do samochodu, światła są czerwone i nie mogę się połączyć, czy wiesz, jak to naprawić? [/ QUOTE]
    Just try to update the tester many times.
  15. #13
    Aug 2010
    Italy
    Grazie mille!!!
  16. #14
    Jan 2020
    Does it require to send to someone activation file or I can just download Post #5 if my serial number is 30250?
  17. #15
    Dec 2014
    PL
    Quote Originally Posted by NOking View Post
    It's enough if you download "For 2016.0" from post # 5.
