Hi! Are you using a win 8-10 tablet pc?
(try to factory reset or recovery to remove everything and reinstall windows)
Try to install win 8 or 8.1 and install the software .
Don't work.
I also delete the next files:
C:\Programsx86\Autocom
C:\Programsx86\Delphi
C:\users\**USER**\AppData\Roaming\Delphi
C:\users\**USER**\AppData\Roaming\Autocom
C:\users\**USER**\AppData\Roaming\Microsoft\System Certificates\My
i cleaned the registry with ccleaner.
restart the computer.
I reinstalled again and asked for the activation again to try again.
thanks a lot yassin .
can anyone help me please.
I have a china clone delphi scanner and works fine with delphi 2013.
I have downloaded 2016 delphi software and have updated the drivers etc..
When i choose a 2015 car or any car, it doesnt work. when i click on eobd it doesnt work either.
anyone ever had this issue?
SW 2016.0 and 2017.01 versions do not work above 2013-2014 y However, EOBD should work. The last good SW versions are 2013.3, 2014.2 and 2014.3 (autoscan ISS does not work in 2014.3)
Mario6 (19th April, 2020)
Hello!
can help me for activation?
Merci j'ai une ancienne version 2013
100251
Quelqu'un pourrait m'aiguiller ?
i kneuw where you can get one
help i need sofware delphi or autocom 2013 of the vcp autocom clon china , no found my cd please
thank
Hello
Need help with activation
Hello Ryko2004, I also have the 2013 version, I installed the 2014 version it works well without uninstalling the 2013 the 2 work, but I use the 2014. Then I installed the 2016 version without uninstalling the 2 other versions it always works, always use the latest version if the others are still installed to avoid conflicts.
Bonjour, moi aussi j'ai la version 2013 100251, j'ai installer la version 2014 ça fonctionne bien sans désinstaller la 2013 les 2 fonctionnent, mais j'utilise la 2014. Ensuite j'ai installé la version 2016 sans désinstaller les 2 autres versions ça fonctionne toujour, il faut utiliser toujour la dernière version si les autres sont toujours installés pour éviter les conflits.
