twardytygrys
Yes. wow 5.008.2 can work with del ... and auto ... on one laptop. You need to paste FW 1423 into software del ../ auto .... Then there will be no update request from the tester.
twardytygrys
bezzveze (22nd February, 2021)
Here you have everything.
http://autocom.ucoz.com/down.html
"скачать" (download), "прошивки" (FW)
If you want to stay at 2014.3 then download and change only FW from 1430 to 1423. Copy / paste. Later, only the update of the tester and will work with wow.
I do this: Updates wow. 1423. What now? Is copying fw until del 2014.3 or 2016.0? But which file and where?
Hi does this later version of delphi 2016 still work with the older interface the silver one without changeable id ?
thank you all in advance
mark
Just try it. At the most, you will have to buy another tester with PCB V3.0 for 35 $. (2016.0 has a lot of bugs, the best versions are 2013.3 and 2014.2)
Has anyone an idea how to get a newer database for this autocom? For example for the opel insignia 2016?
Hello. Im having issues with Delphi It does connect to engine, breaks and bdm, but not to instrumental climate and restrains.
When using op com it connects to modules what Delphi cant connect to. Can you give me a lead where to look for solution
Thanks! AUTOCOM + DELPHI 2016 + KYGEN ACTIVATION
vitalcaffee (26th May, 2019)
-Autocom/Delphi 2016.0 is worst cracked version ever maked from mr. hex2stuff.
-Pretty much bad work of Cars software and very-very bad work Truck software...many model of truck can not read.
-Truck version also have problems on some windows OS, after each restart or turn off of PC, then ask again and again for registration.
So version 2016.0 is waste of time...
bezzveze (22nd February, 2021), Carsoft2003 (29th August, 2019), dmerkovic (21st March, 2019)
Bueno, si no puede resolver todos esos problemas, no los descargue y listo, muchas personas en nuestro gran foro son útiles y pueden trabajar todos los días.
this is dk enjoy it
Mario6 (6th February, 2019)
Who can help me with a autocom 2016 download link more stable.
