Page 3 of 22 FirstFirst 1234567813 ... LastLast
Results 31 to 45 of 324
  1. #31
    Dec 2014
    PL
    twardytygrys
    Quote Originally Posted by twardytygrys View Post
    Does delphi work with WOW on one computer?
    Yes. wow 5.008.2 can work with del ... and auto ... on one laptop. You need to paste FW 1423 into software del ../ auto .... Then there will be no update request from the tester.
  2. The Following User Says Thank You to Mario6 For This Useful Post:
    bezzveze (22nd February, 2021)
  3. #32
    Jan 2019
    Quote Originally Posted by Mario6 View Post
    twardytygrys
    Will del itself paste this software? Do I have to look for him somewhere? Now I have del 14.3
  4. The Following User Says Thank You to twardytygrys For This Useful Post:
  5. #33
    Dec 2014
    PL
    Here you have everything.
    http://autocom.ucoz.com/down.html
    "скачать" (download), "прошивки" (FW)
    If you want to stay at 2014.3 then download and change only FW from 1430 to 1423. Copy / paste. Later, only the update of the tester and will work with wow.
  6. The Following 5 Users Say Thank You to Mario6 For This Useful Post:
    ayllon308 (8th March, 2019), bezzveze (22nd February, 2021), jococ (10th November, 2019), Nobokazu (1st February, 2019), sep382 (25th April, 2019)
  7. #34
    Jan 2019
    I do this: Updates wow. 1423. What now? Is copying fw until del 2014.3 or 2016.0? But which file and where?
  8. #35
    Feb 2019
    Hi does this later version of delphi 2016 still work with the older interface the silver one without changeable id ?
    thank you all in advance
    mark
  9. The Following User Says Thank You to Canoldy2 For This Useful Post:
  10. #36
    Dec 2014
    PL
    Just try it. At the most, you will have to buy another tester with PCB V3.0 for 35 $. (2016.0 has a lot of bugs, the best versions are 2013.3 and 2014.2)
  11. #37
    May 2017
    Has anyone an idea how to get a newer database for this autocom? For example for the opel insignia 2016?
  12. The Following User Says Thank You to donomarion For This Useful Post:
  13. #38
    Dec 2014
    PL
    Quote Originally Posted by donomarion View Post
    Maybe hex2stuff or Luis Andre. Ha, ha.
  14. #39
    Nov 2018
    Lithuania
    Hello. Im having issues with Delphi It does connect to engine, breaks and bdm, but not to instrumental climate and restrains.
    When using op com it connects to modules what Delphi cant connect to. Can you give me a lead where to look for solution
  15. The Following User Says Thank You to ernis1554 For This Useful Post:
  16. #40
    Jul 2018
    Thanks! AUTOCOM + DELPHI 2016 + KYGEN ACTIVATION
  17. The Following User Says Thank You to Bedo13 For This Useful Post:
    vitalcaffee (26th May, 2019)
  18. #41
    Dec 2014
    PL
    Quote Originally Posted by ernis1554 View Post
    If you can not connect with some controllers, so the blame for this is software 2016.0 (a lot of bugs) or you have a tester with a shi.... PCB V 5.0, 6.0, 8.0 or 9.0. Try another software for example 2014.2 and check what PCB you have. The best is V 3.0.
  19. #42
    Junior Member tango5's Avatar
    Jun 2010
    In the neighborhood
    -Autocom/Delphi 2016.0 is worst cracked version ever maked from mr. hex2stuff.
    -Pretty much bad work of Cars software and very-very bad work Truck software...many model of truck can not read.
    -Truck version also have problems on some windows OS, after each restart or turn off of PC, then ask again and again for registration.
    So version 2016.0 is waste of time...
  20. The Following 3 Users Say Thank You to tango5 For This Useful Post:
    bezzveze (22nd February, 2021), Carsoft2003 (29th August, 2019), dmerkovic (21st March, 2019)
  21. #43
    Nov 2011
    friend and friend
    Bueno, si no puede resolver todos esos problemas, no los descargue y listo, muchas personas en nuestro gran foro son útiles y pueden trabajar todos los días.
    this is dk enjoy it
  22. The Following User Says Thank You to arvedo For This Useful Post:
    Mario6 (6th February, 2019)
  23. #44
    Feb 2019
    Who can help me with a autocom 2016 download link more stable.
  24. The Following User Says Thank You to om12345 For This Useful Post:
  25. #45
    Dec 2014
    PL
    Quote Originally Posted by om12345 View Post
    All you need is on the first page of this topic.
