Page 17 of 22 FirstFirst ... 71213141516171819202122 LastLast
Results 241 to 255 of 325
  1. #241
    Dec 2014
    PL
    Quote Originally Posted by al70 View Post
    Sorry mario, i have 2016 cpd, it's a double pcb with nec relays, it connects to everything i've tried so far, ford, vag, psa, but i tried 2009 volvo v40 and 2011 volvo s60 D3 and no communication, any input would be appreciated, maybe i have to rework obd plug, cheers, goodluck.
    The reason for the lack of connection may be a bad PCB V 8.0 / 6.0 or 9.0. The 2016.0 software is also faulty and may also cause a connection failure. You can still try wow wurth 5.008.2 ML or DEL / AC SW 2014.3.2 MD Final.
  2. The Following User Says Thank You to Mario6 For This Useful Post:
    al70 (26th January, 2020)
  3. #242
    Nov 2017
    I can't update the ds150e firmware. Throws an error message. 2015R3 and 2016 not working, it also wants to upgrade the firmware. What is the solution?
  4. #243
    Dec 2014
    PL
    Quote Originally Posted by pinterto View Post
    What firmware is currently in your tester? Just stay with the old FW. Copy / paste old fw to a folder in a new SW. For example, paste old 1423 instead of new 1513. In the new FW, change the name and leave it in the folder too. (Firmware1513) The software will use "Firmware" without any additional name.
  5. #244
    Jan 2020
    Why i cant download it its soo annoying i was even sign in and register and still cand download wt hell...
  6. #245
    Jul 2019
    Thanks! Voy a probar
  7. #246
    Jan 2020
    I probably bricked my delphi, it wanted to update firmware i stopped it now when i plug in into car the lights are red and i can't connect, do you know fix to this?
  8. #247
    Dec 2014
    PL
    [QUOTE = Javado; 3780906] Prawdopodobnie zamurowałem moje delphi, chciałem zaktualizować oprogramowanie, zatrzymałem je teraz, kiedy podłączam do samochodu, światła są czerwone i nie mogę się połączyć, czy wiesz, jak to naprawić? [/ QUOTE]
    Just try to update the tester many times.
  9. #248
    Aug 2010
    Italy
    Grazie mille!!!
  10. #249
    Jan 2020
    Does it require to send to someone activation file or I can just download Post #5 if my serial number is 30250?
  11. #250
    Dec 2014
    PL
    Quote Originally Posted by NOking View Post
    It's enough if you download "For 2016.0" from post # 5.
  12. #251
    Oct 2019
    thanks a lot
  13. #252
    Feb 2020
    thanks for this
  14. #253
    DK Veteran deffc0n's Avatar
    Aug 2009
    UK/POLAND
    I have problem is run kg antyvir off still get info:
  15. #254
    Feb 2020
    Hello
    I need the delphi 2016 keygen.
    Can somebody help me please
  16. #255
    Dec 2014
    PL
    Quote Originally Posted by BMWFreak View Post
    Hello
    I think you should read the first page of this topic carefully. Then you will find.
