Page 20 of 22 FirstFirst ... 101516171819202122 LastLast
Results 286 to 300 of 324
  1. #286
    Apr 2020
    Quote Originally Posted by Mario6 View Post
    Karine
    Try again. (AC, 100251, cars)
    The internet doesn't matter. Automatic updates are turned off.
    Don't work.
    I also delete the next files:
    C:\Programsx86\Autocom
    C:\Programsx86\Delphi
    C:\users\**USER**\AppData\Roaming\Delphi
    C:\users\**USER**\AppData\Roaming\Autocom
    C:\users\**USER**\AppData\Roaming\Microsoft\System Certificates\My
    i cleaned the registry with ccleaner.
    restart the computer.
    I reinstalled again and asked for the activation again to try again.
  2. #287
    Top Poster sandu007s's Avatar
    Aug 2011
    Hi! Are you using a win 8-10 tablet pc?
    (try to factory reset or recovery to remove everything and reinstall windows)
    Try to install win 8 or 8.1 and install the software .
  3. #288
    Jan 2020
    the northern region of the Netherlands
    thanks a lot yassin .
  4. #289
    Dec 2018
    can anyone help me please.
    I have a china clone delphi scanner and works fine with delphi 2013.
    I have downloaded 2016 delphi software and have updated the drivers etc..
    When i choose a 2015 car or any car, it doesnt work. when i click on eobd it doesnt work either.
    anyone ever had this issue?
  5. #290
    Dec 2014
    PL
    SW 2016.0 and 2017.01 versions do not work above 2013-2014 y However, EOBD should work. The last good SW versions are 2013.3, 2014.2 and 2014.3 (autoscan ISS does not work in 2014.3)
  6. #291
    Dec 2018
    thanks for the reply.
    do you know where i can download a working version of 2014.3?
    also so why does the 2016 versions exist if they dont work?
    regards
  7. #292
    ricked's Avatar
    Apr 2016
    Europe
    Quote Originally Posted by Thiss098 View Post
    regards
    dont be lazy and search for it...
  8. The Following User Says Thank You to ricked For This Useful Post:
    Mario6 (19th April, 2020)
  9. #293
    Apr 2020
    Hello!
    can help me for activation?
  10. #294
    Dec 2014
    PL
    Quote Originally Posted by kostakiscoach View Post
    Hello!
    Try and report. (Del. 100251 Cars)
  11. #295
    Apr 2020
    Merci j'ai une ancienne version 2013
    100251
    Quelqu'un pourrait m'aiguiller ?
  12. #296
    Jul 2016
    i kneuw where you can get one
  13. #297
    Newbie alfonso1976's Avatar
    Dec 2019
    help i need sofware delphi or autocom 2013 of the vcp autocom clon china , no found my cd please
    thank
  14. #298
    Mar 2019
    Scandinavia
    Quote Originally Posted by alfonso1976 View Post
    thank
    VCP autocom?
    learning by doing, learning by experience... please thx is I helped you
  15. #299
    Apr 2020
    Hello
    Need help with activation
  16. #300
    nbtechnic's Avatar
    Jan 2016
    Hello Ryko2004, I also have the 2013 version, I installed the 2014 version it works well without uninstalling the 2013 the 2 work, but I use the 2014. Then I installed the 2016 version without uninstalling the 2 other versions it always works, always use the latest version if the others are still installed to avoid conflicts.
    Bonjour, moi aussi j'ai la version 2013 100251, j'ai installer la version 2014 ça fonctionne bien sans désinstaller la 2013 les 2 fonctionnent, mais j'utilise la 2014. Ensuite j'ai installé la version 2016 sans désinstaller les 2 autres versions ça fonctionne toujour, il faut utiliser toujour la dernière version si les autres sont toujours installés pour éviter les conflits.
