Results 1 to 4 of 4
    UK
    Default MSV70 cloning question
    Got a 325i 2006 manual transmission ecu with water damage..
    7 559 178
    Dme MSV70
    5WK98081
    I've found a replacement ecu with matching numbers but it's from an automatic transmission. My question is will this ecu be compatible? If i clone all data from original with it then become manual transmission or is there a HW difference aswell?
    if this post was usefull
    please press
    the thanks button
    Mar 2013
    Europe
    You can Clone without Problem
    Read & Write BDM ;-)
    Few weeks ago Read & Write BDM with Ktag and Fgtech V54 without Problem
  3. The Following User Says Thank You to bersch8688 For This Useful Post:
    looly (7th November, 2018)
    UK
    Quote Originally Posted by bersch8688 View Post
    So hw is the same. Even though 1 ecu is manual transmission and the other is from automatic? Cloning Sw will convert automatic to manual transmission?
    please press
    the thanks button
    Mar 2013
    Europe
    I think yes!
    Write full with eeprom ;-)
  6. The Following User Says Thank You to bersch8688 For This Useful Post:
